Hi my son has a 2001 v70 2.4 petrol N/A.
we've just replaced front suspension, on restarting engine runs as normal until brake leaver is depressed then the engine starts to hunt getting progressively worse until engine stalls. can't find any obvious vacuum leaks. any ideas?
v70 engine hunting ( varying rpms ) Topic is solved
pauluscamperman
- Year and Model: 2003 v70
- Has thanked: 7 times
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 481 times
On mine the vacuum is assisted by a pump that I can hear cycling on off as I start down the driveway, just a quiet hum on and off.pauluscamperman wrote: ↑24 Jul 2020, 11:07 Hi my son has a 2001 v70 2.4 petrol N/A.
Its barely louder than the fuel pump. You probably wouldn't notice if it wasn't cycling by ear, but it would steal vacuum at startup..
Does it go away once the engine warms up.?
pauluscamperman
Hi, the problem remains at all engine temps
pauluscamperman
HI Vac system is sound with no leaks, but seem to have resolved issue as car threw an O2 sensor code, I can't explain why the code did not come up sooner but car is now back to normal
- Has thanked: 1506 times
- Been thanked: 3818 times
Added to title to help those wondering how Volvo engines can run and hide
