Glad it’s been running well! Don’t get it from IPD, just use FCP. Way cheaper plus a lifetime warranty.valvolvo70 wrote: 29 May 2020, 14:56 Did the glove test yesterday, got the "high 5" when I goosed the engine so its looks like a PCV replacement...$265 at IPD? dang! I also pulled the dipstick after replacing the cams seals, I don't drive far even when I go out. Still running great and no CE light which has been illuminated for 5 years.
Engine died while driving and won't start. Topic is solved
- Has thanked: 317 times
- Been thanked: 531 times
- valvolvo70
- Year and Model: 1998 V70 T5 249K
- Has thanked: 10 times
- Been thanked: 8 times
[/quote]
FCP Volvo PCV Breather System Kit - 850T200 is $279. Is there another option I don't see?
https://www.fcpeuro.com/products/volvo- ... bo-850t200
[/quote]
Duh... forgot you have a '98 and need the large hose to the PTC. I wouldn't get anything but genuine Volvo parts for this stuff, so I guess it comes down to whichever one you'd like to order. Either pay the extra $15 for the lifetime warranty or just save a couple bucks with iPd (rare for them) since you probably won't have to do it again for a long time.valvolvo70 wrote: 30 May 2020, 07:47
- Has thanked: 312 times
- Been thanked: 818 times
If you want to shave some bucks off the cost, there are some DIY solutions for the large hose. Best is to use fuel line search for the method posted here by user tryingbe. Don't use cheap heater hose. But the other, molded hoses must be Volvo branded (pick your favorite supplier) and if you go the DIY route you have to piece together a kit.
- RickHaleParker
- Been thanked: 980 times
1. Use Oil gallery brushes to clean out the hoses.
2. Smoke test all the hoses for leaks.
3. Clean out the Oil trap.
4. If all checks out, reuse.
Active
Past
Past
- valvolvo70
***UPDATE*** That was fun
...Installed a new PCV (lots of gunk) and it made quite a difference in performance, also cleaned the PTC. Have negative pressure (sucks glove in) on the oil filler cap. Still have an oil leak, drivers side/rear of engine, which started a few months ago when it backfired. Thought a new PCV would help. Need to get under it to see where its coming from, checked both cam seals to rule out blown seals.
- valvolvo70
Best photo of this repair...blew the top off the oil trap.
![Image]()
- IMG_7092.jpg (142.12 KiB) Viewed 1803 times
- Has thanked: 1611 times
- Been thanked: 4075 times
Boom!
That happened on its own or did you pull it apart? Wow!
- valvolvo70
The top was loose as I was unscrewing the hose clamp, you can see oil residue all around the lower half. The other hose snapped right off plastic and all.
- 1291 Views
Last post by FL850_1997
- 3621 Views
Last post by lummert
- 19 Replies
- 3976 Views
Last post by cn90
- 14 Replies
- 3479 Views
Last post by dj_v70
- 1570 Views
Last post by sleddriver
