Tethys 17" rims on to an 850 (17 spoke)
echosierra
Year and Model: 1995 855T
Post by echosierra »
These are originally for the S60 and have slightly different offset than the Columba that is currently on my 850. +1" wider, +7mm greater offset. My rough calculations is about +3/4" on the inward side, +1/2" on the outward side, compared to my Columbas. Otherwise should fit (same pattern and hub size)
Has anyone else put these on a 850 and experienced rubbing? good fit?
volvo 17 spoke.jpg (81.68 KiB) Viewed 1093 times
1995 855 Turbo
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
ET 50?
Nope!
ET 49 is the highest offset which can fit 850 and NOT wider than 205 tyre with this ET.
No problem if you install spacers.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Pretty common in the UK, with spacers. Still rubs on full lock though, even with C70 lock-stops.
