FDPP #2
Has thanked: 1611 times
Been thanked: 4073 times
The strut comes off the car, the spring gets compressed, old parts removed, new parts on.
Plan a half day for both sides,
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Yes, that’s the correct way to do this. You need to remove the strut assembly from the car to disassemble it.
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
abscate wrote: 31 Jul 2020, 20:30 The strut comes off the car, the spring gets compressed, old parts removed, new parts on.
I'm only fixing the right side, since that's the side with the bad strut.
gnalan wrote: 31 Jul 2020, 21:27
That’s fine. It’s “ generally accepted practice “ to renew struts in pairs, so once done, drive it around a few corners to get a feel for any asymmetry in handling. Tough times require these choices.
It’s not dangerous if you drive it like an adult. If you do go the shop route, you might get some upsell about how only doing one will make your car explode.
gnalan
Post by gnalan »
Since the strut is pretty much bottomed out at this point I'm sure the handling will improve once it's replaced, and it'll be safer than it is now.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
gnalan, I agree with what everyone else has said. I checked and I do have a decent boot also.
gnalan
Post by gnalan »
I haven't had a chance to pull the wheel off and check everything that's been suggested yet. Should I just go ahead and pull the strut assembly out and give it a good look over, or is it something that can still be done with it on the car?
Just curious, volvolugnut, where are you located?
gnalan wrote: 01 Aug 2020, 13:34 I haven't had a chance to pull the wheel off and check everything that's been suggested yet. Should I just go ahead and pull the strut assembly out and give it a good look over, or is it something that can still be done with it on the car?
If you take it off you will, of course, not be able to drive until you put it back on. Personally, I would wait until I had parts before removing the strut assembly.
I am in Oklahoma. Too far for a road trip. Is Circleville the place that has a big pumpkin festival?
gnalan
Post by gnalan »
volvolugnut wrote: 01 Aug 2020, 13:42 I am in Oklahoma. Too far for a road trip. Is Circleville the place that has a big pumpkin festival?
Yes, Pumpkin Show. Unfortunately, they canceled it this year because of COVID-19.
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
I have an old (functional) LSM for a non-front-fog light equipped P2. Let me know if you still need one.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
