This is what Jimmy 57 is talking about.
There is a mechanical thermostat in the Air intake hose that switches over to warm air pulled around the exhaust when it is cold. It might be stick on warmed air intake.
For turbo engines, the MAP unit on the pipe from the intercooler to the throttle and intake manifold is a Manifold Absolute Pressure sensor and measures only pressure and not temperature.On turbo‘d P2’s the IAT is not built into the MAF. It is on the outlet side of the intercooler, just before the air goes into the intake plenum (pipe). It is also referred to (on turbo’d cars) as the MAP sensor or BPS (Boost Pressure Sensor).
Do you have pictures showing how to do this, or a link to a video? This sounds a lot easier than what I was thinking of doing in my head.
Misfiring like crazy after the car is up to temp, and barely drivable through town now. I got 135 miles out of 7/8ths of a tank of gas on my last fill up, but I did/do have a fuel leak I either have fixed now or still need to fix.
