Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Tried to drop you a pm regarding those cupholders, abscate, but it's been in my outbox for two days now.
Has thanked: 1505 times
Been thanked: 3818 times
Cookeh wrote: 27 Aug 2020, 03:27 Tried to drop you a pm regarding those cupholders, abscate, but it's been in my outbox for two days now.
Got it last night, just replied. Daughter comes back sep 10, might be tight to order to her
Cookeh
Post by Cookeh »
abscate wrote: 27 Aug 2020, 03:33
Oh apologies, I thought that because it was still in the outbox there was a problem in delivery. Didn't intend to hassle you.
It stays in your outbox until I pick it up...pm is a bit weird like that
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
1. Replaced my starter in the parking lot of my local Indie's shop because I had a junkyard unit in the trunk and they're nice guys. It solved my intermittent no start issue so hopefully that rules out my immobilizer and key column. Feels dumb that I was chasing such a simple problem for so long.
2. I originally brought the car to the shop for them to pair the new (FCP, Volvo reman) throttle body to the car. The guys are nice but they tend not to trust anything that doesn't come from Volvo. In their words and experience they said a white sticker unit straight from Volvo doesn't need to be programmed, so when it was running like a tractor they thought it was the ECU or something. I put my old unit back in the car and it ran fine, which they were baffled by. ETS light is back on so I'm thinking I'll just go to a dealer for the programming.
3. I had also put a Delphi MAF in from FCP at the same time, but got a new CEL code I hadn't seen before, p0171. Read up on it and it looked like it could be related to the MAF so I just put my old unit back in. We'll see if it comes back.
4. Brought my car to get an alignment after putting in that c70 delta link. Looks like I'm getting some rubbing on the outer wheel wells over bumps and sharp entry to inclines where the back end gets bogged down. I guess it shouldn't be a surprise as it added 2 inches to the track width. I looked into it and talked to a guy who intentionally did this swap on an 850 for stance reasons and he said he got rub real bad too, so he rolled the fenders. I don't feel like swapping a delta link again so I guess I'll be doing that soon.
07 V50 T5 AWD M66 ~146k miles
Cookeh
Post by Cookeh »
May I be incredibly cheeky? If I recall correctly you've recently put a C70 delta link into your car. I've been looking for a rear arb for years now, and I've finally been offered one - from a C70.
Given your recent findings regarding track width, I now have no idea if this part would be compatible with my 850. Is there any way you'd be able to measure the distance between the mounting areas on the C70 delta link and compare it to your old delta link assembly?
That may also help figure out where the additional 2" of track was added.
smacknab
Post by smacknab »
Cookeh wrote: 28 Aug 2020, 02:16 May I be incredibly cheeky? If I recall correctly you've recently put a C70 delta link into your car. I've been looking for a rear arb for years now, and I've finally been offered one - from a C70.
For sure, I'll go take a look at it some point today and let you know.
Cookeh
Post by Cookeh »
smacknab wrote: 28 Aug 2020, 06:22 For sure, I'll go take a look at it some point today and let you know.
That is excellent, thank you very much.
Just remember to correct for Imperial centimeters
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
The general consensus on the C70 delta link is to use it on an 850/S/V70, depending on your wheel setup, you will likely need to roll the fenders.
I'm interested to see where the extra length comes from, and if it's anything beyond just slightly longer trailing arms.
