V8 with funny start up sound
NorCal1985-245DL
Year and Model: 1985 245DL
Post by NorCal1985-245DL »
Hi,
I recently purchased a 07 xc90 v8. I’m not familiar with the vehicle yet and was wondering if this sounds normal with a cold start up or is it something to be concerned about? After the engine warms back up the sound goes away.
Thanks in advance,
David
IMG_0133.MOV
(74.14 MiB) Downloaded 142 times
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
It's definitely one of the pulleys. I recommend replacing the two idler pulleys ASAP. They are known for seizing up and ripping off the timing cover... and the repair is not cheap or easy. Idlers are around $50 a piece, whereas a new timing cover is $350, plus another $400 in gaskets and whatnot.
The tensioner may also be an issue, but that doesn't tend to lock up like the idlers do. You can also check all of the pulleys by removing the serpentine belt and feeling them for play. I bet the idlers both feel pretty nasty.
NorCal1985-245DL
Thanks for responding. How do I get to the belt to remove it and check the pulleys? I can’t find any repair info on the web. Is it a simple to do or do I need a shop?
bmdubya1198
It's not too hard to remove with the right tools. Here is a great writeup. https://forums.swedespeed.com/showthrea ... eplacement
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
I agree, the bearings on one of the pulleys is dry and probably likely to fail soon. Depending upon the exact failure, that can damage the timing cover (which they are bolted to,) and be quite an involved repair. Much better to replace them before they seize.
You could disassemble and figure out which pulley is squeaking and replace just that one, or you can replace the belt and everything it turns, and not need to tough it again for 100k miles. That would be two pulleys, the tensioner, and maybe the water pump, too. It's a fair bit of parts, but then it would be done.
Note on the tensioner - it's not cheap. Some people disassemble and replace just the bearing on the pulley, others do the whole thing. (I've just done the whole thing.)
Good luck!
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
bmdubya1198
Roger_850T wrote: 04 Sep 2020, 18:23 I agree, the bearings on one of the pulleys is dry and probably likely to fail soon. Depending upon the exact failure, that can damage the timing cover (which they are bolted to,) and be quite an involved repair. Much better to replace them before they seize.
Good luck!
Roger
You can order the tensioner pulley separately? I didn't know that.
As of now, I think Tasca comes in cheapest on the tensioner at around $187.
Roger_850T
bmdubya1198 wrote: 04 Sep 2020, 22:34
I've heard of some people going as far as to remove and replace the bearings from both the idlers and the tensioners. It really brings the cost down, if one has the tools to do it. (I do not. I wish I had a good press!)
I did look it up, and if I'm reading my notes correctly, the bearing (at least the idler) is SKF # 6203 2RS JEM. Aka Grainger 23Y203 at $14.15 each.
Let me know if you try that route, I want to know how it goes, and specifically how you get the old bearing out!
Roger
11 XC60 137k
05 XC90 V8 213k
bmdubya1198
Roger_850T wrote: 06 Sep 2020, 22:07 I've heard of some people going as far as to remove and replace the bearings from both the idlers and the tensioners. It really brings the cost down, if one has the tools to do it. (I do not. I wish I had a good press!)
Roger
Huh... interesting. I may look into that. If I do it, I'll certainly post a thread with the results!
NorCal1985-245DL
I decided to take it to a volvo mechanic today and had the 2 idler pulleys, the belt tensioner and belt replaced. plus a software update. He said there was a small leak in the power steering pump but I decided not to replace it. In hind sight perhaps that was the source of the noise.
$1300 dollars later and I hope the noise is gone. I’ll find out tomorrow morning when I start it up.
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
Sad part about the power steering pump, it's not going to stop seeping and you'll need to pull the belt (tensioner) again to replace. Can see photo for where it starts, drips out the front of the engine under the pump and makes a mess but eventually runs to the rear of the engine through the valley, confusing the source of the leak. One truth about the Volvo V8 in my opinion, sooner or later you'll replace the pump. Mine started seeping at 125k miles.
