P80 (-1998) Throttle Body Rod 3507883 Dicussion
- Been thanked: 4068 times
Options
Could one possibly buy a Porsche cup and install on the rod?
The 10 cent solution.
I copy you on the perisbability of a rubber band but my guess is if you replace at each oil change they will be fine
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
I beleive I read that turbo cars and N/A cars had different length rods, is that correct?
Current Volvos:
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Its down on my '96 850. No record in service history of anything being done that would have required removal.abscate wrote: 02 Sep 2020, 01:55 Maybe I’m just putting this on upside down?
I’ll check if the “ head with lock nut” is up it down
Volvo web store shows head up.
Service manual claims they are sided and labelled - will attach when on a PC.
- Cookeh
Just found additional figure in service manual for 850s showing "head with locknut" down. See section titled "THROTTLE LINK ROD" in the following link:
http://www.volvotips.com/index.php/850- ... -and-850r/
- SonicAdventure
- Year and Model: 1996 850 wagon
- Has thanked: 59 times
- Been thanked: 12 times
I've already talked with Abscate about this part - managed to salvage one from my parts bin. Will ship it next week.
I don't like this part. It feels very cheap. The fact that the knobs are steel and these cups are plastic with no retainer mechanism other than plastic and pressure gives me an uneasy feeling. I can't imagine the dread of trying to merge onto a highway in traffic or pull out of a driveway near a busy road and having this fail.
I'm already thinking of a way to fabricate a new version of this part for my '96 when I get it back from the shop. Ideally, I'd like to see this 100% made from metal being so close to the engine block and associated heat. One idea involves two lengths of threaded rod with a threaded coupler in between them.
- SonicAdventure
I like the fact that these have the metal retainer springs like a rear hatch gas shock would have. Seems a much better system to me vs. a plastic pressure fit. A piece of the stainless threaded rod between two of these with adjustment nuts below each metal cup and some Loctite holding it all together would be a good investment in my opinion.
- Cookeh
Random thought popped into my head; given you lot are US based and still have a plethora of carb driven vehicles on your roads, I imagine it would be fairly easy to find a metal carb link rod that would fit?
- SonicAdventure
Here is the same part in my '96. The heavier end of the rod is on the "top".
It was installed the same way on the '98 n/a intake.
- asasasa.jpg (81.64 KiB) Viewed 753 times
- 10 Replies
- 597 Views
- 2713 Views
Last post by manovlov
- 2606 Views
Last post by shaker_chi
- 1674 Views
Last post by charleskennedy23
- 1367 Views
