Hello,
I've attached a picture of the strut that is out of whack on the driver's side, and the one that appears normal which is on the passenger side. Anyone know what may be wrong with it? Hoping for an answer before I dive in there. The cap doesn't turn when I try to turn it by hand.
Thanks,
Eric
2000 Volvo V70XC strut issue
- RickHaleParker
- Been thanked: 980 times
Broken strut mount. Not uncommon. Grab and hold the fender, keep your eyes on the Strut. Bounce the car up and down.
The Strut mount can be replaced on the Strut. If you don't know what your doing it is best to take the Strut and new Strut mount to a repair shop and have them install the new Strut mount on the strut. If you lose control of the spring on the Strut it can do some serious damage even kill you.
Active
Past
Past
- Has thanked: 2207 times
Rick, the picture is the strut bearing plate and not the mount. The mount is a rubber part.
What you are seeing with the picture Richard99 is the center bush in the top mount has separated from the mount. Like Rick says this is a common issue with Volvos of this era.
Volvo replaced the regular part with the one from the XC90 as it was much stronger and tells to fails less often.
Try to use brands like Sachs or OE or Lemforder
https://www.fcpeuro.com/Volvo-parts/V70 ... d=665&v=87
Take Rick's warning on replacing this part on the strut seriously. Compressed springs can cause a lot of damage if they break loose!!
- RickHaleParker
Click on the picture it is linked to the listing at FCP Euro.scot850 wrote: 06 Sep 2020, 22:50 Rick, the picture is the strut bearing plate and not the mount. The mount is a rubber part.
It is call the Strut mount because it mounts the upper end of the Strut to the the body.
Active
Past
Past
I have never seen a bearing plate/mount break. I'm sure anything can happen. It is the rubber spring mount that fails as per my link to FCP web-site.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
I have a safety related question.
Is there a fuse at the battery end of that large red wire?
Sooner or later, the threads it's rubbing against will short it
to ground, and after the fire, struts will no longer be an issue.
Just sayin'...
Just sayin'...
- Been thanked: 4071 times
Needs both fuse and chafe relief.
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 23 times
Thanks. I will place a fuse in-line. I'll also find a way to reroute the wire.
Eric
Eric
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
- BEJinFbk
There are a couple of pass throughs in
the firewall near the steering column.
+1 on the XC90 spring seats.
And spend the money on OEM,
not the cheap stuff. The less
expensive seats do not last.
- 11 Replies
- 8030 Views
Last post by BackRoadSeeker
- 2376 Views
Last post by oragex
- 1282 Views
Last post by precopster
- 1194 Views
Last post by Vovo_merz
- 973 Views
