V70XC - 10th day into reaching oil leak in Final Drive
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
RosserV70 wrote: 08 Sep 2020, 22:25 I know this is super old- but are there any tricks to removing the two rear axles? Is it a matter of disconnecting the two wheel hubs and they pull out? I need to replace the output seals in the final drive. Couldn't find anything in VIDA.
The cradle must be lowered while bringing the final drive down with it. It then provides space for the rear axle to slide out form the rear subframe. Check to make sure you replace the cir-clip if there is one -- replace the output seal (corteco) to finish the reinstall.
