Title says it all, I have a stubborn 1996 850R that wont start 20% of the time. Its completely random, when the engines cold, when the engines hot, after running all day or first thing in the morning, pretty much whenever it feels like. But when it does start
80% of the time, it runs perfectly, doesnt miss a beat, doesnt stall, runs like a dream. Then if I turn the car off, theres a 20% chance it wont start again. In this case I have to try cranking the car over several times over a period of 5 minutes to an hour, and 90% of the time the car will then start before completely draining the battery. I cant understand why it may have issues starting, but when it fires up runs so well. There is a spark at the HT leads, fuel pressure at the rail and no CEL. Ive tried letting the fuel pump run for a few seconds before starting, sprayed easy start down the intake, (engine tries to run on this so i have spark?) cleaned the distributor, changed the plugs and none of this has worked, im thinking my next step is the cam sensor or fuel relay? Ive read a lot of threads online about intermittant starting and running bad but if my car starts it runs and drives perfectly until i shut it off. What should i look into next?
1996 Volvo 850R Random no start but runs perfectly
- slickdizzy
- Year and Model: 1996 Volvo 854 R
- Has thanked: 9 times
- Been thanked: 15 times
Sounds like a classic fuel pump relay failure to me. The part is quite cheap so I’d start there.
~Desmond (Current: 1996 854 R, Past: 1998 V70 GLT, 1997 855 R, 1988 744 Turbo, 1993 965)
- Been thanked: 4068 times
This
Has to be measured in psi or hPa
To troubleshoot fuel delivery. Just looking at a spritz from the valve is not sufficient.
I took a second in applied math so I cringe at random , when pseudo-random Is correct. Sorry about my issue.
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
Remove the fuel pump relay when the engine refuses to start. Insert a large paper clip into 15 and 87 slots. The fuel pump will run continuously with the key in the on position. Be careful, the paper clip will get HOT in a few minutes of engine on.
If the car still won't start, it may then point you to a fuel pump problem. Most of us 850 owners carry a spare fuel pump relay in the glove box.
Klaus
Just tried jumping the slots 15 and 87. Fuel pump runs constantly when I do that but still no start. I have no way of accurately checking fuel pressure unless i buy a tool for doing it. Should I try changing the fuel pump or look at the cam sensor? I heard some people have trouble with the coolant sensor too
- 1868 Views
Last post by Tundra12
- 2185 Views
Last post by precopster
- 11 Replies
- 4786 Views
Last post by volvolugnut
- 5564 Views
Last post by SwissXC90
- 1190 Views
Last post by dosbricks
