2014 S60 T5 P0016 code triggering CEL, 58k miles, runs perfectly
Hello, just starting to research an issue that has come up with my wife’s car. As the title says, 2014 S60 T5, 58k miles, absolutely NO issues whatsoever. The car runs perfectly, no symptoms, but the “check engine light” came on yesterday. I checked the code with a very basic code reader, it showed P0016, with the same code “pending” several other times. I cleared the code and began searching for its meaning. Read a little, and was intimidated by it being timing related. I am, what I would call, a parts changer! I’m no mechanic, but I have no issue changing sensors or any parts for that matter, but the word timing makes me nervous. I just wanted to check here to see what others have experienced with a relatively newer car, with no other symptoms, other than the check engine light, with a P0016 code.....? By the way, started the car today, it ran for approximately 5 mins, and the same code returned. The oil is full, decent condition, and no obvious signs of running rough or stalling or anything. Any opinions or suggestions would be greatly appreciated.
HectorVolvo
- Year and Model: 2014 S60 T5
Hey bud I have the exact problem with my 2014 S60 T5. My computer reads P0016 that’s the only code that I have anyways I took it in to Volvo of Ontario here in California the service provider told me it was the VVT Solenoid so they replaced the Intake Solenoid but that didn’t fix the problem he then said next was the VVT Hub and quoted me at $800 bucks to replace it. I said no thanks I was wondering if you got yours fixed if so what was the problem thanks.Tundra12 wrote: 10 Dec 2018, 11:35 Hello, just starting to research an issue that has come up with my wife’s car. As the title says, 2014 S60 T5, 58k miles, absolutely NO issues whatsoever. The car runs perfectly, no symptoms, but the “check engine light” came on yesterday. I checked the code with a very basic code reader, it showed P0016, with the same code “pending” several other times. I cleared the code and began searching for its meaning. Read a little, and was intimidated by it being timing related. I am, what I would call, a parts changer! I’m no mechanic, but I have no issue changing sensors or any parts for that matter, but the word timing makes me nervous. I just wanted to check here to see what others have experienced with a relatively newer car, with no other symptoms, other than the check engine light, with a P0016 code.....? By the way, started the car today, it ran for approximately 5 mins, and the same code returned. The oil is full, decent condition, and no obvious signs of running rough or stalling or anything. Any opinions or suggestions would be greatly appreciated.
Sorry to hear about your troubles. I actually ended up going to a local guy that was supposedly “good with Volvo’s.” He explained to me about a part that was somewhat internal, something like a oil pressure reset switch or something. He had seen it before. Him being able to fix it would’ve required several specialty tools from Volvo to hold everything in place during diss assembly. I never researched it further. Ended up trading the car to a Volvo dealership. I told them during the trade that it had a check engine light on, wasn’t sure what it was. They never questioned it at all. Traded, left, and the salesman later contacted me regarding something else. He made numerous comments about the “headache” my trade ended up being. I feel that I did my part by earning them of the light. I’m sure this is of no help to you, just telling you my experience. Hope you get it squared away.
- 1449 Views
Last post by Matty Moo
- 1096 Views
Last post by Volvovlo
- 2071 Views
Last post by highmiles
- 757 Views
Last post by Liason
- 2185 Views
Last post by precopster
