ETS light on, no symptoms, codes
pgregston
Year and Model: 92 960 wagon
Post by pgregston »
just test drove a 2000 V70 with 151K miles. Drove great. Starts easy. Stops great. Solid and yet faded and thus offered at decent price.
The ETS light is on, so took it by AutoZone where they will check codes for you, and it had no codes.
Given that the car zips up to speed, idles well, and showed no codes, what other things would account for the light being on?
Other details about the ownership are a bit sketchy- guy showing it 'for a friend that doesn't speak good English' and staying at a hotel.
But mostly curious about how this light happen and the car seem to drive well. What problems lurk beneath and can such a car pass CA smog with that light on?
Has thanked: 2212 times
Been thanked: 1853 times
What is an ETS light? Is it the traction control light? If that is what you mean then it should have no effect on the cars running but could point to the ABS controller failing which is common on these cars. Strange though that it is not showing a code. Did Autozone re-set it and did it come back on?
If it was not re-set then I would re-set it and see if it returns.
The traction control light can be triggered by several things but the main 3 are:
1) Failing ABS controller (See Mid-West ABS web-site for more info)
2) Bad ABS sensor on one of the wheels, or a bad reluctor wheel on an axle
3) Failing ignition switch electrical portion.
Has thanked: 1613 times
Been thanked: 4075 times
Electronic Throttle System. It’s the full name for the Electronic throttle body and all of its cousins
ETM, ETB, AND ETS all refer to the fly by wire system used by Volvo in 1999
Your 2000 Volvo uses theMagneti Marcelli throttle body that lasts , 150k miles
A new one costs about $500 and sometimes you need software loaded at the Volvo dealer for another $200
There are third part options discussed in the ETM Forum below
Get licenses, and transfer money at a police station
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
pgregston wrote: 19 Sep 2020, 19:55 just test drove a 2000 V70 with 151K miles. Drove great. Starts easy. Stops great. Solid and yet faded and thus offered at decent price.
If you can find someone to scan it with VIDA before purchase, I'm almost sure you'll be able to see why the light illuminated.
2023 Lexus RZ450e -66k
