04 V70 2.5T MAF reads way high, no codes, stalls out Topic is solved
ZachS
Post by ZachS »
It's certainly some sort of leak. Went for a drive with MAF unplugged. Past 2500RPM it sounds like a racecar, but has no boost. Gonna have to check the intercooler and anywhere else for obvious leaks.
ZachS
Post by ZachS »
Whelp, figured it out. Intake pipe came off throttle body. Probably didn't put it on tight enough when I did the PCV. How do you make a post say solved?
Been thanked: 4065 times
jimmy57 wrote: 01 Oct 2020, 09:04 If you ruptured a hose anywhere between turbo outlet around back to throttle you'd have your symptoms. Intercoolers can split at core to end tank seam also so that needs to be checked. The turbo can pump air out of the leak as it is driven enough by exhaust the moment you start engine to force the air out. You do not have to open throttle to get turbo sped up enough for this to occur on low pressure turbo engines. The MAF is registering that air. If no leaks then failed MAF sensor is possible.
Whose got the Volvo Horns? Looks like they need to go back to Texas , again.
Thanks, Jimmy!
This failure brought me to MVS 7 years ago!
