98 V70 Echoing Clunk in rear
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Hi everyone,
Ill try to put up a recording tomorrow, but recently i have been hearing an echoing clunk in the rear on the drivers side. The car drives in a straight line, but if i go over a speed bump, i hear a clunk (like metal striking metal) that seems to echo through the car. Normal driving will not cause it to clunk, and i took a quick look under the car and found the following. The springs seem to be fine, shock absorbers look good, no excessive rust on any of the suspension components. It does not sound like the delta link bushing found in other videos, but i will need to look at it closely.
Im hoping its something small as i just dropped 200 for a weld in flex pipe and exhaust manifold gaskets + labour.
2008 S60 2.5T Auto (Sold)
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
Hy,
I would check these parts circled round. I had recently something that sounds strangely like your issue. You say "no excessive rust...".
Manov
Rear springs.png (171.1 KiB) Viewed 517 times
Has thanked: 1507 times
Been thanked: 3822 times
On my 1999(s) there is a cup on the lower spring seat that gets loose and rattles. I don’t see it on this diagram, so maybe you don’t have it on a 1998?
Details here.
viewtopic.php?f=1&t=85762
Editorial comment. The P80 rear suspension has to be one of the most robust in the business. I know the delta link job is tough, but how many makes run 200k\25 years miles with no parts replacements ?
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Do you mean number 10 in Manov's image, sitting beneath the upper spring seat in the top left circle? The item pictured here? Nivomat (L) and standard (R)? If so, I have also had clunks from these loosening.
Cookeh wrote: 04 Oct 2020, 05:38 Do you mean number 10 in Manov's image, sitting beneath the upper spring seat in the top left circle? The item pictured here? Nivomat (L) and standard (R)? If so, I have also had clunks from these loosening.
That’s the part!
The diagram is confusing because part 10 actually sits below the spring, down in the lower spring seat, with a small index pin to stop it from rotating. A single hex bolt holds it in, and can get loose.
yanga001
Post by yanga001 »
Checked both delta links and they seem fine, i added some pictures to illustrate the lack of "excessive rust"
The delta link bushing on the side that makes sound
The side that does not make sound:
The side that makes sound
yanga001
Post by yanga001 »
Ill check out what you guys mentioned, thanks for the help!
