bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
smacknab wrote: 13 Oct 2020, 12:30
Wow yeah that's quite a bit, 1 time was enough for me for awhile
I pulled mine on the 1/4 ton as well due to the short reach, and I still mamed my front license plate
Yeah, I always try to put something between the jack on the hoist and the front bumper. For the S60R, I just removed the bumper cover. Made for a little more room.
Those foam mats work pretty well to protect everything.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
bmdubya1198 wrote: 12 Oct 2020, 17:50
MoVolvos wrote: 12 Oct 2020, 14:13
Is that makeup (silver eyeliner) original?
It is. Not sure if it depends on trim level, but the S80 is similar to the NedCar S40 in that there were many headlight variants.
Kinda cute on the white but wouldn't want that on my black 03 S80.
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
abscate wrote: 12 Oct 2020, 18:24
brunocerous wrote: 12 Oct 2020, 12:41 Of course, after pulling the starter, bench testing it successfully and reinstalling it, having the car start right up, the '98 V70 T5 is now back to square one with a no-crank, no start.
Whiskey TamgomFoxtrot?
My sentiments exactly. I’ve been meaning to comb through MVS to get back to troubleshooting, but it’s been hard to find the time with all the kids’ online learning.
This week I also threw in the towel on the Eurovan with nice, new timing chains that also doesn’t start and had it towed to the family mechanic. That is, the mechanic our family uses, not the mechanic in our family. :)
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
Swapped my clutch sensor today, and of course it STILL spikes the revs on shifts if I'm heavy on the throttle. Really odd... is this normal?
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
This evening I mounted new rear rotors and pads on my bmw. Tomorrow I will await my first mechanic to come home from work so we can bleed the brakes.
I looked at the receipt i found in one of the boxes and it turns out it was almost to the day one year exactly since i purchased them. Is that why my wife accuses me of being a procrastinator? I dont know. Here are some assorted pictures:
BMW 540i 2002
S70 Base 2000
Has thanked: 1502 times
Been thanked: 3817 times
One year of careful testing before installation, darling.
A very good friend of mine has a habit of buying parts for a job and then finding out he bought them earlier. I have found sticking with a single vendor reduces the Factor Chance Probability.
5rivers
Year and Model: V70 1998 T5
Been thanked: 14 times
Post by 5rivers »
Began to lower the subframe on my '98 V70 and have one tie rod and one sway bar link that do not want to leave home! The tie rod is really stuck in the hole from the knuckle, and the bolt holding the sway bar link turns with the nut. Used heat last night and lots of PB blaster on tie rod bolt/knuckle. Will try heat again on the knuckle/bolt area this morning to remove the outer tie rod from its captive spot. Any other suggestions? Not sure what to do to the nut and bolt that turn together on the link. Am hoping to remove a leaky power steering line and its side kick and replace with new, and remove the rear lower motor mount and replace with new.
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
On that link nut....
Use your jack to lift your link a few inches and put pressure on the taper. Then zip it off with an. Impact
Heat for 60mseconds with propane, try not to melt the boot though.
I’ve got a tie rod end popper if you are really stuck
duke1
Year and Model: 855 1994 10v
Has thanked: 416 times
Been thanked: 34 times
Post by duke1 »
hi all today i cleaned the scuttle drains and 1 the drivers side uk was blocked completely im hoping and praying the damn carpet dries out now as i been pulling my hair out trying to ensure the water stays in the cooling system and because she had leaking matrix for ages before i got her the carpet is so full of anti freeze already and add ingress of rainwater to this and i have one very soggy floor!
so far ive not had warm enough weather for anything to dry at all and been raining for days,god knows how long it will take to dry!peace
Please use stops on sentences and paragraphs on topics per Forum rules.
Oxford commas show class, verve, and elan; truly properties we covet.
