Does the coolant lubricate the water pump?
Richard99
Year and Model: 2000 V70XC
Has thanked: 26 times
Been thanked: 23 times
Post by Richard99 »
Curious if the coolant lubricates the water pump on these cars? I had an incident where I was low on coolant, so I fixed the issue, refilled the coolant, and there was a horrible screeching sound for about 20 seconds that gradually went away.
Eric
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
Has thanked: 311 times
Been thanked: 817 times
No. The bearing around the water pump shaft is sealed, if coolant comes in contact with the bearing it will actually ruin it by stripping out the grease.
The coolant can help to cool the bearing I suppose, but not to lubricate it.
I don't know how to explain the screeching.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Spilled coolant will make the belt squeal
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
jimmy57 wrote: 19 Oct 2020, 22:37 Spilled coolant will make the belt squeal
I thought by adding moisture to a worn dry or loose belt provided friction so it's one of the methods to test / eliminate a squeaking belt. It could also be a coincidence but he could spray some 303 to soak the belt for a day and it should not come back, unless; the idler bearing is starting to go, belt is loose, worn or both or worse case the water pump is starting to go.
https://www.amazon.com/30340CSR-Protect ... r=8-2&th=1
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
Richard99 wrote: 19 Oct 2020, 19:47 Curious if the coolant lubricates the water pump on these cars? I had an incident where I was low on coolant, so I fixed the issue, refilled the coolant, and there was a horrible screeching sound for about 20 seconds that gradually went away.
Eric
I just installed an Aisin (?) (volvo) water pump. In the box was a prominently printed note warning you NOT to rotate the impeller without coolant in there to lubricate things. So, the bearing itself is sealed, but the tolerances are so close (at least on the OEM pump) that the impeller will score the casting. Note says that if you score the casting, the pump could make a high pitched noise forever after. Just reporting what was in the box.
All U.S. market models.
All running and on the road.
Good info Eddystone thanks!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Eddystone wrote: 20 Oct 2020, 15:30 ...I just installed an Aisin (?) (volvo) water pump. In the box was a prominently printed note warning you NOT to rotate the impeller without coolant in there to lubricate things. So, the bearing itself is sealed, but the tolerances are so close (at least on the OEM pump) that the impeller will score the casting. Note says that if you score the casting, the pump could make a high pitched noise forever after. Just reporting what was in the box.
That note is also present in SKF water pump box.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Been thanked: 4065 times
Vida solution for squealing water pump is “remove sus scrofa”
Outside Don Beyer Volvo in VA
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Many years ago I worked for a general engineering contractor who had 55gal drums of water soluble oil that they used in their heavy equipment. We used a little bit in our personal vehicles as well. Seems like it would make sense on a couple if levels; maybe less corrosion.
1999 V70 GLT
