2007 xc 70 turbo 230k miles code P
raquette
Year and Model: 2010 xc90, 2007 xc70
Been thanked: 4 times
Post by raquette »
Code P0420 Catalyst Efficiency Below Threshold (Bank 1)
Is this o2 sensor the one ahead of the cat on a 5cy turbo?
raquette
Post by raquette »
ttt - anyone?
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
That single code is not enough to tell what the problem is on your car. Do you have the ability to see live data? What you want to look at is the activity of the pre-cat and post-cat O2 sensors. Fuel trims would also be helpful to as the code could be caused by an air leak.
raquette
Post by raquette »
decided to replace both sensors - $200 from FCP -parts coming this week. that sensor wire connector under the intake tube to the turrbo is a bear...
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
raquette wrote: 02 Nov 2020, 16:04 decided to replace both sensors - $200 from FCP -parts coming this week. that sensor wire connector under the intake tube to the turrbo is a bear...
theres a couple of videos on yutube regarding the connector.
