Code P0420 Catalyst Efficiency Below Threshold (Bank 1)
Is this o2 sensor the one ahead of the cat on a 5cy turbo?
2007 xc 70 turbo 230k miles code P
- SuperHerman
- Been thanked: 207 times
That single code is not enough to tell what the problem is on your car. Do you have the ability to see live data? What you want to look at is the activity of the pre-cat and post-cat O2 sensors. Fuel trims would also be helpful to as the code could be caused by an air leak.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
theres a couple of videos on yutube regarding the connector.raquette wrote: 02 Nov 2020, 16:04 decided to replace both sensors - $200 from FCP -parts coming this week. that sensor wire connector under the intake tube to the turrbo is a bear...
- 2374 Views
- 18 Replies
- 11324 Views
- 801 Views
Last post by Steve H
- 5441 Views
Last post by wizechatmgr
- 990 Views
Last post by raquette
