...and ships biscuits!
- Has thanked: 987 times
- Been thanked: 1075 times
My wife and I somehow came up with Snow Rules. When there is snow on the road, you can yell Snow Rules! and then slow but not stop at stop signs. The details of snow rules are there are no rules. It is best to do this before anyone else gets on the roads.
volvolugnuty
volvolugnuty
- Been thanked: 4068 times
Just soying, you may have fallen out of Fava with that post.
Used my V70 T5 to haul 8 foot cedar boards home from the lumber yard. Rear seat down and passenger seat moved forward. The boards are for house trim.
moncureww
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 3 times
Changed my angle gear fluid on my 216k mile 2006 s60 AWD. It was dark and smelled bad. I'm going to give it a second change at the next oil change to get the fluid baseline clean.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
If AG fluid is similar to something like 90 weight gear oil, it just stinks, not because it’s old.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Well, the P2 was PO'd as the O3 Odyssey sat for 3 months or was that 4 in my folks garage so I couldn't get its control arms bushings started. Yes, still haven't clear enough room in my garage to do any short term work since moving in 5 years ago. Last hurtle was to inspect and potentially rebuild the calipers. Who does "parking" brake shoes anymore, that's another part of this saga. Wait, spoke too soon, I think the S80... If anyone decides to rebuild calipers they are not all created equal.
First, the good. The Odyssey pistons were still highly polished so no sanding of the caliper bore nor replacement kit needed. Was able to pull it out of the dust cover but the bad was being unable to get it back in through the small opening. Second, and getting worse, thought the dust boots were somehow pressed into the caliper. Looked seamless, spent hours trying all sorts of methods, crafting tools to return the piston into the small opening till... I really did cleaned and examined everything and didn't see the split, besides it was seated in there like it was part of the caliper. These high tolerance Japanese engineers. The ring is really smaller than it looks in the picture
. Thanks for letting me digress.
Will resume the control arms bushings rebuild programing soon.
People often get lost on long trips in the Odyssey
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Michelins generally give good tread life, but at the expense of traction. I have found with age/wear after about 30k miles the tread surface goes rock hard. They still have lots of tread depth but virtually no wet weather or snow traction thereafter, even if they might wear for another 20-30K miles. That's always been my experience with Michelins.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
