foamy power steering fluid
This topic is in the MVS Volvo Repair Database » Foamy Power Steering Fluid -- and Groaning Sound -- 2001 V70 T5
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Re: foamy power steering fluid
Post by oragex »
IVIUSTANG wrote:I suggest anyone having problems with the 2001-2004 reservoir to simply replace it with the 2005-2007 reservoir. It has design improvements which have eliminated these issues.
Jesse
The re-designed 2005-2007 reservoir has a different hose to the pump, so make sure to get the reservoir along with it's own hose.
csh
Year and Model: 2004 S60 AWD
Has thanked: 5 times
Been thanked: 3 times
Post by csh »
Dredging up an old thread to say that I just hit this same problem where the plastic tube came off the brass tube and the fluid foamed up causing the pump to make noise. I fished it up and reattached it, but that it only lasted 5 minutes before coming off again. Oh well. A new reservoir, suction hose, and fluid have been ordered. I guess I can't complain too much, this one has lasted me for over 100k miles. I had the original one replaced while the car was still under warranty because it was leaking. This thread probably saved me a lot of time figuring out why the fluid as foaming up.
oragex
Post by oragex »
You could have got a used reservoir with hose off ebay, this is the newer model that has no longer that brass piece inside https://www.ebay.com/itm/99-07-OEM-Volv ... ondition=4
csh
Post by csh »
Thanks for the suggestion oragex. Too late for me, but could be useful for the next person that finds this thread.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Be sure to flush it first then install the new items. I used this method on an 03 Odyssey, 03 Lexus GS300 and 03 S80 T6. Attached the hose to the reservoir as on the second video.
