'03 s60 needs good engine shop
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Re: '03 s60 needs good engine shop
Post by vtl »
I had a head resurfaced at home as well. Was 0 mm W and 0.05 mm L in one spot only. Managed to have all zeroes.
Finding a flat area of a 3/8" thick glass. You get the head as flat as the glass is.
Dykem steel blue (wasn't really needed)
3M adhesive
18 sheets of 220 grit 3M sandpaper (the best one) and 18 of 400 for the final mirror-like surface (not actually needed)
This is a wet sanding, so some WD-40 is needed:
See the high spots?
Got his:
From this:
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
Great job.
The best Lathes have the bed hand lapped/scraped to get that final accuracy. Better than the machine can do.
Machine is just way faster and close enough for engine heads.
vtl
Post by vtl »
jonesg wrote: 15 Dec 2020, 15:57 Great job.
Yes. Having good tools does help. However I went low this time, the biggest investment was a $50 glass shelf ;) I actually had parts from the donor engine, just in case I screw it up, but it turned out pretty well. With all the consumables the head resurfacing project still was under $100 plus few beers, I think.
Has thanked: 1505 times
Been thanked: 3818 times
I would love to know the details of how much time and pressure was used on the head. Did you just move it back and forth by 15 cm? How many passes ?
vtl
Post by vtl »
No pressure! The head is heavy enough, you just need to push and pull it, as horizontally as you can.
Because of a fine grit and wet sanding it took a few hundreds of passes, but in return it gives you a precise control of how much material is removed. I stopped when I had a couple of cavities reduced to a level where a new head gasket would seal it properly. It could be the coarse grit was even 320, not 220, forgot which one it was. 220 would work as well, however it need more frequent controls.
I think the sheet is a standard letter size, the head fits on two sheets with a good margin, so one stroke is slightly over 11" or 28 cm.
SantaFe75
Year and Model: 2003 s60
Has thanked: 16 times
Post by SantaFe75 »
abscate wrote: 15 Oct 2020, 04:03 Volvo horns awarded for removing 6 thou of warp with sandpaper!
That’s dedication !
Did you use new head bolts? That’s recommended by Volvo but I’ve always wondered if they are truly in the deformation limit
You had to go there :D . No, I know that I should have. When I was ordering the h2o pump, pulleys, belts,..... I forgot.
I did tighten all to spec., and so far no problems. The boy has been cruising her daily.
SantaFe75
Post by SantaFe75 »
vtl wrote: 15 Dec 2020, 14:00 I had a head resurfaced at home as well. Was 0 mm W and 0.05 mm L in one spot only. Managed to have all zeroes.
Very nice job.
That's how I did it. I didn't have the blueing, but I have a ton of sharpies.
SantaFe75
Post by SantaFe75 »
jonesg wrote: 14 Oct 2020, 16:18 good job, any problems encountered ?
Sorry so late.
I always have problems :D . Time, was my biggest issue. When I measured cam gaps I found that they were well worn.
Most (16) were within spec. I did try to find single lifters, but with our Volvo dealer closed, there were none to be had
in time. I believe the worst had a gap of +.07 over "max". Needless to say, My "Volvo tick" is prominent. When I can get
the needed lifters, I'll pop the cover off and do it again.
For what it’s worth I measured a whole set of removed head bolts and was unable to measure length differences from a Volvo one, within resolution of =-50 microns. I doubt they are torqued past elastic deformation, so reuse isn’t crazy
I just removed a valve cover on an RN and retorwued head bolts to address an oil seep, so far successfully
jonesg
Post by jonesg »
SantaFe75 wrote: 29 Dec 2020, 16:56
Sorry so late.
don't they sell valve shims for that?
