What did you put off doing to your P2 Volvo today....... Now Sticky!
VTs70T5M
Year and Model: 1998 s70 t5m
Has thanked: 2 times
Been thanked: 3 times
Re: What did you put off doing to your P2 Volvo today....... Now Sticky!
Post by VTs70T5M »
Lol i just got the same sticker set Dec 20th with my bosch coil pack. The i wrench euro I'd on the back window of my xc90..
The s70 t5m only gets performance stickers because racecar...
VTs70T5M
Post by VTs70T5M »
And to stay on topic I put off lca bushings on the xc90 and filled the buggers with windo weld 😂..
1 more month till I move into my 1st owned house with heated garage n 9ft post lift.
No more gravel dented shoulder blades yaaa..
Then I can finally upgrade that stock clutch in my fairly kind of fast s70...
I will say I'm impressed it's listed max clamping force of 275wtq and didn't budge til near 400wtq...
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
VTs70T5M wrote: 24 Dec 2020, 01:25 And to stay on topic I put off lca bushings on the xc90 and filled the buggers with windo weld 😂..
Can I move in with you? :lol: It'll add another 10% to your wtq. :D
Has thanked: 292 times
Been thanked: 765 times
erikv11 wrote: 12 Apr 2018, 07:55 The blower motor has been squeaking all winter on the S60. So I bought another blower and put it in the garage. Problem fixed! Basically.
Noticed this motor is still in the garage.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
erikv11 wrote: 25 Dec 2020, 12:29
It's still sitting in the garage.
'06 S60 R, 197k
Has thanked: 1505 times
Been thanked: 3818 times
Now it’s two years older…
Picked up my alternator from my Godlike Auto Electric Guy
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
This thread feels like I'm going to a confessional.
I've needed a new windshield for the past 3 months...
I've had my rear silencer hanging on a piece of coat hanger for 4 and had the replacement bracket for 2 months...
04s60 2.4
04xc70 2.5t
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 114 times
Been thanked: 263 times
Post by Blacklab467 »
Threw the hounds in the car and went out for a run in the mountains, came home and put together a parts list for the coming winter. I'd like to replace the squeaky blower motor but the Volvo one is over $300. Does anyone have any experience with the OEM one that FCP sells for $140 ish? I cannot justify $500 CDN on a heater fan that still mostly works but squeals on speeds 1 and 2. Also put a parts list together for turbo hoses and gaskets and o-rings, etc. I have to R&R my propshaft so I thought it would be a good time to pull the angle gear and give my turbo some love, any advise on what parts to replace while I'm in there that I may have missed?
2003 XC 70 (sold)
Blacklab467 wrote: 23 Aug 2023, 19:41 Threw the hounds in the car and went out for a run in the mountains, came home and put together a parts list for the coming winter. I'd like to replace the squeaky blower motor but the Volvo one is over $300. Does anyone have any experience with the OEM one that FCP sells for $140 ish? I cannot justify $500 CDN on a heater fan that still mostly works but squeals on speeds 1 and 2. Also put a parts list together for turbo hoses and gaskets and o-rings, etc. I have to R&R my propshaft so I thought it would be a good time to pull the angle gear and give my turbo some love, any advise on what parts to replace while I'm in there that I may have missed?
The Mahle Behr is probably OEM and will work fine , at $140. You don’t have to worry looking for nearby cubs either.
I think I would pass on the siren song of PPS at $80
Your labs seem to have shedded their black fur.....or did you try URO lab black?
We still have but one cat , in 019
Blacklab467
I'll probably roll the dice and try the Mahle and see if I can restore the original while its out and keep it on the shelf. We've had many labs, mostly in 019 but wound up with these last two in 093 by coincidence.
2003 XC 70 (sold)
