1999 V70 base 417/beige NA 550192 “Shaggkira (2023 no longer in service)
Forum rules
Been thanked: 4065 times
Purchased oct 2020 as a project car, leaking oil from head gasket, 232k
viewtopic.php?p=554497&hilit=Nautic+blue#p554497
Build date 8/98 Ghent (early 1999 model year Build)
Beautifully maintained and clean 417 Nautic Blue wagon
Driver power seat fore aft inop
Evap circuit not ready
Removed cover in fall amd retorqued head bolts, seep seems to be alleviated? :lol:
Replaced rear calipers and rear brake pads
Radio code 4111
Cruise control inop, found loose plug at wheel. Now working
Courtesy lights inop, loose plug at console. Repaired cracks with epoxy
2021 sercvice records
March2 oil change at 233500
Replaced console light with new from Tasca, repaired heater box vacuum hose with 3 mm silicone blue
1April Replaced muffler with FCP STARLA
Order #:
R443273752
Snout to bell was a bit loose so sealed with putty and permeatex epoxy wrap, clamp. Installed driver kick panel
Pulled Shaggkira driver seat, shampood carpet.
Fore aft motor stuck on driver. Tested motor, stalled. Removed motor, runs. Gear box apparently seized, or runners seized. I used my other 99 to mark a seat position that fits three ladies that drive this car and set the runners there.
Swapped in a nice arena/ wood console and swapped in driver kick panel.
Fixed shifter knob by trimming plastic to allow release.
July 2021…replaced radiator to reservoir hose due to hole from ps pulley abrasion. Added 1 liter make up oil at 237300
Installed 2019 battery
Drain fill 4 liters atf valvoline max life dex6
Replaced o-rings on upper atf hose
238400 new Volvo 3 prong plugs. Coils date 2015. Car is popping a pretty quick P0440 for major evap leak. Rear canister style. Volvo code is ECM4047 vap canister shutoff valve blocked or canister purge valve leakage Inspected j and L j]hoses, appear ok
239200. R/r front left wheel bearing with FAG. Treated and painted brake backing plate with hammertoe. Installed 9492980 Volvo wheel seal
viewtopic.php?f=1&t=45096
Swapped I working power driver seat from Dirk
Welded 60 mm bosal cat pipe to Starla muffler
Oil change filter 241041 August 30 2021 10W-30 Castro’s synHM
Installed air guide. 8mm head bolts instead of 10mm
November 11 242732 added one liter make up oil
Replaced right from headlight wiper
Quick RN alternator notes
Remove negative battery terminal
Car ramped, remove air guide, 2 10mm M6
Remove SERP belt, 14mm hex tension release
Remove plastic ECu box
Remove three 12 mm M8 bolts through ps pulle
17 mm wrench , remove PS high pressure line
Move PS out of way
1 m8 12mm bolt rear of alternator top
2 m8 long bolts, 12 mm hex bottom of alternator
Under car, ease 2 m8 12mm bolts bottom AC compressor
Release alternator
13 mm m8 release positive alternator cable
Unplug alternator exciter wire
Tetris alternator out of car
Second occurrence of hot start problem August 239800
No firing after refueling on Thruway
Needed 5-10 seconds cranking with gas pedal fully depressed. Fired, then ran roughly.
Possibles. ECT. Fuel pump relay. Fuel pump
2022 records
Jan 1 244300
Jan 5 swapped in two TYC headlights
May 19 246300 miles , oil due at 247500
June 10
Oil after 750 mile MA to DE round trip, mid hash mark
Topped off with 100 ml coolant 50-50
Left rear brake light bulb connection intermittent , bulb/ wire
Slight vibration front brakes?
Upcoming service
18 June oil and filter change. 8mm air guide,17mm oil,917 cartridge , 247250
Fob programming
Front pads rotors
ATF gibbons
Headlight aim
22june. Weak cranking, battery 12.2 bolts at rest, 13.2 idle. Battery 2019-12 AGM. possible alternator or battery cable.
UBG alternator, new Conti serp belt, Volvo cabin air filter
Checked air filter, replaced 2020-04 at 233k
Replaced battery NAPA Legend 2020 07-10, 24 month warranty
New front rotors and VOlvo pads, springs. 11mm bleeders new . All FCP parts
Pushed 250 mL brake fluid through each caliper
Order #:
R494135854
Inspection renewal. Due to battery work had to complete drive cycle
Misfire , fuel , engine went ready on idle
Cat continuous , OXS continuous, HOXS continuous took one drive cycle, 20 miles
Cat non continuous took two cycles 50 miles
Now have OXS NON CONTINOUS AND evap not ready, have 60 liters fuel in tank, a bit too high
Inspection complete
Replaced positive battery with UBHG
Current draw measured at 0.030 Amps
New 2 AWG positives cable, new 6 AWG ALT to starter, parallel ground cable
Installed 5 amp trickle charger for biweekly top off
2023 maintenance placeholder
Jan6 250,000 mile marker. Coding for minor evap leak and Brake position sensor code, cruise INOP. Have UBG sensor, STC TRACS compat?
Jan17 Battery drained after 8 days sitting from highway trip. Could be we killed the battery in the short drive cycle troubleshooting above. With fresh charge , car starts immediately. No codes.
Strategy , measure drain, check battery voltage over days.
Charged full 12.8 volts. 90 mA draw. Next morning 11.8nvolts. Probably bad battery, 6/22 from Napa
Popped an ECM 9400 brake pedal sensor have spare.
Charged battery. 12.8V. Left unconnected. One week later , 12.7 volts. Diagnosis current drsin
3April 252xxx #3 coil failure on highway. Replaced with UBG, no change
0 psi compression on #3, burnt exhaust valve likely. Disconnected #3 FIJ and drove 200 miles at 60-65, 26 mpg
July 15 2023 Valve job complete
253500
All new hoses including heater hoses and reservoir pipe
Oil filter change FCP
Coolant replaced FCP
July 16
Left light on, dead battery
Jump pack cranked, no start. No ETB initialsing
Charged at 6 amps for 30 minutes, bump vroom
Timing belt, tensioner, idler, water pump done at 208k. Due 320k
Replaced rear tailgate lock and latch. Repaired tailgate cover
July 31 new Napa battery warranty thtough July 2024
14 august. Replace evap line to FPR hose with blue silicone
17 aug NYSI 253888
5 sep checked current drain. 50mA
21Sep car no longer in service due to accident
Notes on Cylinder head job May/June 2023 25x
Engine 1477386 7mm valve stems, hydraulic
easy to forget M8 timing cover bolt beneath exhaust cam
dipstick bolt M8 12mm hex easy with ratchet wrench
Manifold bolt to rear very difficult, cant access underneath. removed metal bracket with 18 inch breaker, 6 inch extension, 12mm hex socket then lifted IM with metal attached. Clean and dont overtorque
Water pipe screws M6 10mm hex - wrench combo?
90 minutes to cam cover removal
Replacements
One cylinder head bolt , hex stripped
Both IM underneath m8 bolts , replace with new
Exhaust studs, down pipe all nuts
Using AE exhaust valves ftom FCP
Valve stem seal kit ordered from lisle
Studs and nuts from Amazon.FCP
Corteco head gasket
Cooling group refresh including heater hoses?
New coolant
Centereach Auto Machine Shop
Head to shop with 2 valves and seals needed. Estimate 10 working days, $350
https://centereach-automotive-machine-s ... m=referral
Notes on head torquing
viewtopic.php?p=627809#p627809
Happy memories of Shagg...1999-2023
Will save those Echo wheels, too
Volvo OEM 16″ x 6.5″ Aluminum Alloy Wheel ECHO Rim 30736594
$312.00
The Volvo OEM Wheel named “ECHO” is a 7 spoke Aluminum Alloy Rim with a silver bright finish. This style wheel was introduced on the Volvo S60 Series in 2006-2008 but is known to fit other Volvo models and years.
