98 XC: making a trailer
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Re: 98 XC: making a trailer
Post by volvolugnut »
CIK7 wrote: 28 Dec 2020, 08:50
scot850 wrote: 25 Dec 2020, 16:03 If you must insist in using concrete blocks as supports, place a piece of wood between the concrete and the car so there is not a point load on the concrete.
I did have 1 jack stand on both sides of the car...until I needed to support the driver side more so I could inspect the gas tank and decide how I'll get that off. Driver side currently has both jack stands with no blocks and passenger side has 3 blocks holding it up. I think 1 2-hole and 2 solid 4" blocks should hold 500lb just fine.
The problem with concrete blocks is they have no warning, they just crumble. They are not intended to support much load other than a widely spread weight from a stack of like blocks. Using them to support a vehicle loads them more than you would expect. I have used them when when I was young and they broke. Fortunately, I did not get hurt and learned not to use them for vehicle support. Get a stack of 2x6 boards or better yet more jack stands. We don't want to have you get hurt.
Has thanked: 1505 times
Been thanked: 3818 times
It's a common error in reasoning to think that because blocks support houses they can support cars
That is false. Do not use them in any form for this please.
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 328 times
Been thanked: 87 times
Post by CIK7 »
UPDATE #4
I tore out the rest of the engine bay minus the brake booster and also the interior front. This is the point at which it becomes difficult because I have to sort all the wiring to figure out which wiring goes and which stays, as well as how to rewire the items I'm keeping. Wiring is a VERY fun activity for me but this sorting will test how many marbles my head has.
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
CIK7
Post by CIK7 »
I have 48 people viewing this right now. WOW! It's fun making this I must admit!
BlackBart
Been thanked: 884 times
Post by BlackBart »
IMO.....
You’d be better off cutting the car cleanly at the front of the B pillar / back of the front door openings. Then you have a strong front corner “ post.” Weld a full height bulkhead across the front face of this shape. Gut the inside, make a flat platform. Weld a tongue triangle on the front, overlapping the frame rails.
What’s the point of having the firewall and windshield and all that weight?
For that matter, a trailer is useful because you can throw things INTO it, not slide them in the tailgate, and to carry tall things that don’t fit in a wagon. Just use an old pickup bed like everybody else does.
CIK7
Post by CIK7 »
BlackBart wrote: 28 Dec 2020, 20:04 IMO.....
Are you referring to a similar cut like the displayed gray trailer?
I want to go with how the displayed blue trailer was done.
Spoiler: This will be a camper and utility trailer. I want to keep the functionality of the folding 2nd row so i can sleep there. I did that about 2 times in this one. And then if I want to help someone move their giant couch and washer or dryer, I will have...about 9.5 feet front to back. I just measured.
Actually I fit my old couch in my previous 01 v70 base which might have 1/2" more or less than the 98 v70. The couch fit from hatch to next to the back of my driver seat (7.5-8ft?). My friend and I tried fitting his pool table in this 98 but the hatch opening was 1/4" too narrow. I need to change that 😃
CIK7 wrote: 28 Dec 2020, 20:30
I think both trailers look cool. I hope you can get your trailer together.
I think you can pull this off without a hitch
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
abscate wrote: 29 Dec 2020, 14:30 I think you can pull this off without a hitch
The Dad gene is strong in this one...
BlackBart
Post by BlackBart »
CIK7 wrote: 28 Dec 2020, 20:30 Are you referring to a similar cut like the displayed gray trailer?
Yep. Those guys spent a great deal of money on those projects.
Blue one kind of gives me the creeps. Also, it will have a lot more tongue weight because of where the wheels are.
Abscate is in fine form this morning.
