Non-Volvo car chat megathread
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Re: Non-Volvo car chat megathread
Post by volvolugnut »
Glad you asked. Piston pumps are used for oil field pumping services which include pumping fluid cement, nitrogen gas, chemicals, and other fluids into wells. They are also used for the fracturing operations on wells that has become so widely reported by media in the last decade. All of these operations require positive displacement pumps because they need to be high pressure to force the materials into the well. Pressure can be 3 to 5,000 PSI for shallow wells and 15,000 PSI or more for deep wells and fracturing operations. These pumps are often 3 or 5 cylinders and can have ratings from 500 to 2500 horsepower. The cylinders (plungers) are 3 to 6 inches in diameter. They generally operate at a few hundred RPM. These pumps are normally of the cross head design to avoid side loads on the pressure plungers.
I could bore you for hours talking about the details.
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Interesting. That's makes sense, low rpm, big loads. So it gradually beats itself to death instead of breaking or ripping apart like a high rpm failure.
This one has six lightweight rods, all in a row......
Has thanked: 1506 times
Been thanked: 3822 times
volvolugnut wrote: 27 Dec 2020, 11:20 Glad you asked. Piston pumps are used for oil field pumping services which include pumping fluid cement, nitrogen gas, chemicals, and other fluids into wells. They are also used for the fracturing operations on wells that has become so widely reported by media in the last decade. All of these operations require positive displacement pumps because they need to be high pressure to force the materials into the well. Pressure can be 3 to 5,000 PSI for shallow wells and 15,000 PSI or more for deep wells and fracturing operations. These pumps are often 3 or 5 cylinders and can have ratings from 500 to 2500 horsepower. The cylinders (plungers) are 3 to 6 inches in diameter. They generally operate at a few hundred RPM. These pumps are normally of the cross head design to avoid side loads on the pressure plungers.
Thank God we banned that in my State. That’s going to be a huge mess to clean as these sites are abandoned for economics
BlackBart
Post by BlackBart »
Lugnut could bore us with tales of boring...?
Pistons and rods never bore me.
on-the-road-to-kyoto-for-the-third-concorso-d-eleganza-in-japan-1jujkdfko-3-780x520.jpg
on-the-road-to-kyoto-for-the-third-concorso-d-eleganza-in-japan-1jujkdfko-3-780x520.jpg (79.76 KiB) Viewed 1197 times
BlackBart
Post by BlackBart »
Coming and going.....
Artebellum 2.jpg (36.8 KiB) Viewed 1197 times
Artebellum1 5-collector-cars.jpg (56.23 KiB) Viewed 1197 times
BlackBart
Post by BlackBart »
250GT SWB comp.jpg (132.01 KiB) Viewed 1185 times
red car.jpeg (197.65 KiB) Viewed 1185 times
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
abscate wrote: 29 Dec 2020, 18:40 Thank God we banned that in my State. That’s going to be a huge mess to clean as these sites are abandoned for economics
A few years ago we where getting earthquakes in Kansas. The epicenters where fracking sites in Oklahoma where regulations where more lax. When the Oklahoma Supreme Court ruled people could sue for damages. The energy companies companies toned it down.
BlackBart
Post by BlackBart »
Identify this slippery car. Not a trick question - I'll have to look it up too. I remember it's a 80s(?) prototype with a Mercedes V12 mid-ship. Pre-aero flaps and wings, but it was very slippery and clearly has venturi tunnels underneath. Clean lines. It had a lot of borrowed parts from the Porsche parts bin - note the 928 headlights.
XXX eeollrv09dxuj1okzucr.jpg (78.7 KiB) Viewed 1147 times
XXX LR tunnels.jpg (65.23 KiB) Viewed 1147 times
XXXrear open.png (677.68 KiB) Viewed 1147 times
BlackBart
Post by BlackBart »
I had to dig it up again...
It's the Isdera Commendatore 112i from 1993. 6 liter Mercedes V12. German car with Japanese funding that eventually fell through. Had designs on running LeMans, hence the long aero tail.
It’s a Miata that overdosed on Viagra
