and at a very bad time. At least I got a jump start and made it home. After getting the car home and shutting the car off, I disconnected the fan at the connector above the radiator that carried power to the fan, and, of course, the fan stops. So what is causing the fan to run all the time? I thought it may have been the climate control, so I pulled fuse 24 (third row in fourth fuse down 10A) in the side fuse block, then reconnected the fan, but the fan still ran. I have to solve this tonight.....
BTW, I'm pretty sure this is Ok, but I would like to check - I want to put the car on an 8 amp charger to get the battery back up enough to start the car. (key is out of the car) Is it Ok to do this under the hood at the fuse block?
2001 V70 radiator cooling fan will not shut off
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
Found this thread:
viewtopic.php?t=50104
Very bad timing on this break down... Anything I can do tonight?
I am close to a parts yard. What is the year range I can pull from to replace the fan control module? I gather I have to replace the entire unit on the 2001 - fan, shroud and module?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
You can charge at the fuse block on the rear battery cars.
A low battery can cause a lot of havoc so charge it then see if the. Fan problem returns
azureblue
Thanks for the charging device. I didn't want to disconnect the battery to charge the car.
As it turned out it was the fan controller that was the problem. I got the whole assembly and dropped it in, and the battery recovered enough in 18 hours to start the car. Glad I went in there - I found a few other things that needed fixing or righted. The PO was a sloppy mechanic - The crossover pipe's clamps were loose.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
cmbfoto
- Year and Model: 99 S80 02 XC70
- Has thanked: 11 times
- 15340 Views
Last post by FREEBUSINESSES
- 9692 Views
Last post by ClarkKent
- 45 Replies
- 6046 Views
- 2760 Views
Last post by cmbfoto
- 676 Views
Last post by DGM
