Transmission going out.
DutchSasquatch
Year and Model: 99 V70 GLT
Post by DutchSasquatch »
Evening gentlemen. I have a 99 V70 GLT FWD auto, I think the trans might be on its way out. It shifts kinda hard, sometimes hesitates, and when i drained the fluid it was BLACK.
My questions are,
Should i rebuild or replace it?
Is a manual swap significantly more work than a rebuild or replacement?
If not what manuals from which cars will work?
If looking for a donor car which models/years have the same auto?
there is a cheap crashed 98 S70 non turbo auto FWD as well as an even cheaper 98 XC on CL, thinking of picking one up if there is good parts compatibility.
Thanks for any advice you can give me!
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Run about two gallons high quality ATF through - pump it out, DO NOT FLUSH IT, and give it a week. Then drop the pan and replace the filter. I'd be willing to bet it's fine but clogged with junk.
Has thanked: 1507 times
Been thanked: 3822 times
DutchSasquatch wrote: 10 Jan 2021, 20:53 Evening gentlemen. I have a 99 V70 GLT FWD auto, I think the trans might be on its way out. It shifts kinda hard, sometimes hesitates, and when i drained the fluid it was BLACK.
My questions are,
I’ve got a good 4 speed AT from a 1998 already removed in very Western VT ready fir pickup, cheap for the Freedy, Free to the Needy. History is it came from Sonics 1998 with about 220k
Most engine parts from a 1998 won’t go to the superior 1999 model, that’s why we drive them.
wizechatmgr
Is this mostly when it is still cold? Reason I ask is the first couple drain and fills I had a horrible time with it sounding like it was slipping and then slamming into gear.
DutchSasquatch
All right, Ill continue to do the drain and fill, and then filter replacement. I'm in vergennes VT, you can hardly get more west than that, maybe I'll come by and say hi sometime, I think I'll wait and see before picking up your tranny. Thanks guys!
wizechatmgr
DutchSasquatch wrote: 11 Jan 2021, 10:46 All right, Ill continue to do the drain and fill, and then filter replacement. I'm in vergennes VT, you can hardly get more west than that, maybe I'll come by and say hi sometime, I think I'll wait and see before picking up your tranny. Thanks guys!
How bad does the fluid look when you're pumping it out? Mine came out like curdled chocolate milk the first couple times. I think I used a total of 4 gallons over a couple months to really get it where it is now.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Dutch, you have the 5 speed auto, correct? If so, the 98s are useless to you. you will be limited mostly to 99 and 2000 models, perhaps up to 04.
Current Volvos:
-1999 4 speed AT
2000- 5 speed AT
Has thanked: 293 times
Been thanked: 765 times
I think there's actually not any filter inside?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
DutchSasquatch
According to rock auto there is a filter in it. The fluid wasn't chunky or anything, just very black.
