The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
Has thanked: 1609 times
Been thanked: 4065 times
Well, -1C/31F today but sunny and clear - so I launched the cylinder head project today.
If early on is any indicator, I cracked the manifold to turbo exhaust bolts, then unscrewed them with my fingers. With no PBB. Nothing. Are these things tungsten?
:D :D :D
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
fascinating... I thought tjey'd be a bear to get loose. Can't wait for your progress. I'll be sippong white wine in the meantime...
1996 855 R,
2010 V70 D5,
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
abscate wrote: 25 Jan 2021, 11:59 Well, -1C/31F today but sunny and clear - so I launched the cylinder head project today.
Your fingers are tougher than mine. And your nose and your ears!
Couldn’t get head off today before winter deluge hit, expecting about 15 cm snow
I got all four exhaust manifold to turbocharger bolts off but the flange angles up, so head won’t come off that.
I’m 4 hours in total at this point. Working a bit slower due to temps and logistics in driveway
S60UT
Year and Model: 2000 V70R
Been thanked: 4 times
Post by S60UT »
Looks like good progress to me !!
00 S70 GLT SE T5 Swap
00 V70R
99 V70 T5
01 E46 325XI Touring
09 FX35 Clown shoe
16 Jetta GLI
Has thanked: 2199 times
Been thanked: 1852 times
Wow, that is a lot of progress in 4 hours in cold temps! Well done. Hopefully you can feel the good will energy being sent your way by all the folks here!
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
I am very impressed. My low temperature outdoor work limit is about 50 F.
Yesterday was easier. I warmed up the engine to drain the oil and after about 15 minutes the engine compartment was nice and warm to work on.
Bit nastier today, but alright for two hours
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Looks like the poor dear will be wrapped in a gentle cocoon of white stuff tomorrow. Pretty astonishing progress given the arena you're playing in. And True Grit for pressing on with the fix once you made the decision. Hope it doesn't look too hateful once the pistons are uncovered.
Usually after a dump, we get a few days of clear skies and sunshine. In the sun, I find it’s nice to work outside even in the cold!
If I can stay on track, it will be about 10 hours all in , not bad at all. Added benefit, access to do the rack will be a lot easier!
Snow Not too bad....
