The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
Has thanked: 292 times
Been thanked: 765 times
Re: The Resurrection of (10/1998 to 01/2021 )Elizabeth 1999 V70T5M56 Cylinder Head Job
I buy head gasket and spark plug tube seals from Volvo. Then Corteco on the cam seals. On the exhaust manifold gasket you can get the one-piece gasket very cheap in Volvo brand so I'd go that way rather than the 5 individual pieces. Intake manifold gasket doesn't matter too much what you get.
If the Victor Reinz is good quality that set is maybe a good option too.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Goetze is also a good quality aftermarket brand for headgasket.
It is a Federal Mogul division.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1505 times
Been thanked: 3818 times
Went Volvo on both stems and head gaskets. It’s an incremental $25 on price and that’s a no brainer on a 12 hour job
Additional job creep on list
Power steering rack, have ordered from Detroit axle
Replace lousy hose clamps on oil cooler lines
Replace cheap clamps on induction path, especially the one on the lower intercooler which snags my belly every time I roll underneath
Turbo control hoses still original, evaluate
Change MT fluid, 100k
Replace rusty clutch slave line
Rebuild starter...already at auto electric shop
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
I justify mission creep with "I'm already working under here and have things apart. Easier now than later."
How's the weather treating your project?
Its about 15 and windy so I’m on break today
Well , I rolled the dice and got snake eyes.
Evita the S70 needs a starter swap today and it’s 2F this morning, amd she’s blocking in SWMBO car
I might burn my outside time on that job today.
+1000 to please SWMBO.
BlackBart
Been thanked: 884 times
Post by BlackBart »
abscate wrote: 31 Jan 2021, 07:05 Evita the S70 needs a starter swap today and it’s 2F this morning, amd she’s blocking in SWMBO car
Push it out into the middle of the street...? Are your neighbors persnickety?
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Well done, keep it up. From what I understand the valve stem seals are made by Volvo, not sure about the headgasket but both are long lasting so it was wise to stick with Volvo.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
With the amount of disassembly, it only makes sense to use Volvo valve stem seals. Hope the weather cooperates for you to get the job done! I'm a big baby about the cold now, it was around 40 today and I couldn't stand it (granted it was raining too...). I've lived in the south too long, my northern blood warmed up :lol:.
