Hello
XC90 was jump started and polarity reversed for one second. Now the entire electrical system is dead. No interior lights. Nothing when the key is turned. Battery has a full charge. I have checked continuity to fuse boxes and all seems OK. I have checked the relays and they seem to be OK as well. There is continuity to the alternator and ignition module.
Can someone suggest what I should check to determine what has been blown?
Thanks
Jonathan
2004 XC90 2.5 AWD - Polarity Reversed
- ZionXIX
- Has thanked: 64 times
- Been thanked: 194 times
I would start pulling relays out and check them for function.
- Has thanked: 927 times
- Been thanked: 1000 times
Check the similar topic links below for other suggestions. Good luck.
Thank you for the replies. Turns out it was the battery. I charged the battery and checked it out under load. All looked fine. Brought it into the shop and it was dead. With a new battery, the interior lights came on and the car started. So far, I have not noticed any damage.
These modern Volvos demand good battery voltage. Cranking speed is a poor indicator of good voltage on these cars, unlike older cars.
- ZionXIX
volvolugnut wrote: ↑07 Feb 2021, 08:48 These modern Volvos demand good battery voltage. Cranking speed is a poor indicator of good voltage on these cars, unlike older cars.
I used to check headlight brightness to determine battery charge
- 1189 Views
Last post by Derbyrunner
- 22 Replies
- 5153 Views
