Feels like it wants to stall Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Out of the blue she was hard to start this morning. Kept dying but finally started idling though not steadily. As I was driving I noticed that when I took my foot off the gas, the RPM's would drop and it felt like it was going to stall. Push on the gas and nothing for a couple of seconds then it would go. Decided that I had better head back home instead of continuing on to work. Just as I got home CEL came on. PO 0171 Fuel bank 1 Lean. Fuel pump and filter are new in the last year. Ditto with fuel pump relay, though that one did come from the JY. Anything else I should be looking at ? I have another relay I am going to pop in and see if that helps.
Doing some searching and I'm thinking o2 sensor. The one thing I haven't replaced.
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Bad fuel with dirt or water? Have you kept tank near full and consumed fuel to turn over fuel at least once a month? Do you use ethanol blend fuel? Winter can be bad for condensation in fuel.
Sveedy
Post by Sveedy »
Don't think fuel is the problem. It was running fine when parked yesterday. Usually fill the tank. Recently have been driving about 170 miles a day so I'm going through some tank fulls. But getting apx 28+mpg. I think I'll hit the junkyard and grab a o2 and a MAF. I know all the hoses are new and tight so it's something I haven't yet touched, I think. Hence the o2. I have never replaced it.
1999 V70 GLT
Sveedy
Post by Sveedy »
Well I pulled the o2 sensor and I'm not sure if I have an issue or not. The sensor has a chalky white look to it. Is that normal for a turbo ? And if it's bad, do I need to stick with Bosch or will others work fine.
1999 V70 GLT
Been thanked: 4065 times
That lean code is pointing to a vacuum leak, either a vacuum hose or an induction leak
Sveedy
Post by Sveedy »
All hoses are new and tight. So is the intake and TB. When I googled the code there were a few mentions of either a bad or dirty MAF ( I cleaned mine 6 months ago ) or a bad o2. That along with vacuum leaks for bringing too much air in. Then fuel delivery problems for bringing too little fuel in. Since I have done the entire fuel system, I ruled that out.
Seems weird that it would be running fine when parked last night, but then all of a sudden a basket case this morning. :(
1999 V70 GLT
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Disconnect Maf and start the car.
If it runs better...Maf or it's connector are bad.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sveedy
Post by Sveedy »
I'll give that a try. Of course I now have everything taken apart. As you know, the best course of action when something acts up, is to immediately take EVERYTHING apart. :roll:
Is the white color of the o2 normal ?
1999 V70 GLT
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
I would go with what Misha said. On my '98 NA, when the MAF went bad, it had problems idling and even maintaining engine speed. Within a couple minutes it was jack rabbiting. Once the MAF was replaced I pulled it apart. There is apparently a ceramic board on mine and it had a hairline fracture. So it would be fine for 2-3 seconds and then go nuts.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Regarding the color of the O2 sensor, I can offer that my O2 sensor was covered with white and slightly pink deposits on the outer surface of the sensing tip. This was the original O2 sensor dated 1996... I replaced it at about 225K miles recently due to a repeated "slow response" code on the OBD2 system. I don't know if the deposits are normal or not.
