hello,
new head job, need to set the timing. are there any markings on the engine that can guide me on how to adjust .
thanks for any advice
240, 1990
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The timing marks should have been aligned before removing the timing belt. If that has not been done you will need to get the N0. 1 piston at TDC before proceeding further.
If you did align the timing marks before starting and they have not been moved all you need to do is ensure the valves are closed on No. 1 cylinder.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
craig Turner
- Year and Model:
thanks matt. correct me if i'm wrong,dose the timing belt and the sprockets have marks that have to match up .
- billofdurham
The timing belt does not have marks that match up with the sprockets. just make sure the teeth sit well into the grooves.
If you are re-using the belt you took off you should have marked it for direction of travel as it may snap if it goes the other way.
Bill.
Bill.
Previously:
Previously:
craig Turner
- Year and Model:
got it started thanks for all the help.Im focusing on the tranny now
- billofdurham
Thank you for the update.
Bill.
Bill.
Previously:
Previously:
- 895 Views
Last post by maverill
- 621 Views
Last post by LikeAGloveBox
