1990 240 DL noisy start
LikeAGloveBox
- Year and Model: 240 DL, 1990
It's making a loud knock on start. Usually a couple. It does start, but after a few times (this just started yesterday) it's taking longer. The next time I try to start I believe I should have a new part or be on my way to the shop. I already tried tightening the starter mounting bolts (although that upper one is hard to reach, so hard to tell how tight it is but I wad able to tighten it some). Is there any chance this is just a starter problem or at this point can I assume I need a new flywheel? I'm not up for that job myself, so is there anything else I can do to rule that out before I take it to the shop?
LikeAGloveBox
Well, it turned out to be the starter. The mechanic even took the time to go to Advance where my old starter was still under warranty, which I didn't even know(replaced 3 years ago at another shop), so less than $100 for his labor and I'm a happy fellow.
- 255 Views
Last post by Pretribrapper
- 952 Views
Last post by maverill
- 1232 Views
Last post by whtwgn
- 583 Views
Last post by 93Regina
- 1262 Views
