bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Wow, that seat looks great!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1243 times
Post by matthew1 »
Very cool Dash Viking, Dirk. That seat is amazing, I agree.
Scranton? Did you say hi to Dunder Mifflin?
Also -> Amazon link
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Just catching up here -
1. Sveedy & bmdubya : What do you use for smoke? I tried to get some oily rags to smolder. What psi do you use? I used a gallon paint can. Mistake I made was choosing clear tubing that got soft when it was hot - it kinked, pressure built up for a second, and blew the lid off the can!
2. Groupil : Nice driving to hit the mileage exactly!
3. Yanga : You don't want a Highlander. Your kids will grow up sad.
4. Chuck W : That task might qualify you to be a rocket scientist.
5. 850LPT : I love the Viking! We have a stuffed Bison from Yellowstone, who wears a bandana, and he goes on adventure trips with us.
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
I ignited some charcoal and sat it on top of a crumpled piece of foil then through cardboard pieces on top. I ran a roadside inflator through the paint can. Worked great.
bmdubya1198
I have an old sock (rag will also work of course) that I soak in mineral oil, then a pen style soldering iron (the $3 harbor freight one) glued to the lid. Looks hilarious, but it does the job! Air pressure comes from a bicycle pump, but super low regulated pressure is ideal. That way you get constant pressure into the system. Most people recommend a propane regulator set to like 1-2 PSI.
I’ll have to post a picture if I think about it tomorrow.
bmdubya1198
matthew1 wrote: 14 Mar 2021, 19:36 Very cool Dash Viking, Dirk. That seat is amazing, I agree.
Finest paper in the industry!
Has thanked: 1502 times
Been thanked: 3817 times
bmdubya1198 wrote: 14 Mar 2021, 23:37
The have a fax machine,that receives faxes.
From the future.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
I used piece of old towel ( apx 3" x 3" ) that I discovered smouldered quite well. Could have added oil to make it smoke better but it seemed to burn well without it. About 5 psi or so. Kind of hard to to use my compressor at that low of a setting but it worked. Opened oil filler cap and pulled dipstick so as to not have pressure build up. Might work better with cap on, but loose, so more smoke can get into the intake but not sure about that. First time I have ever had to do it.
1999 V70 GLT
BlackBart
Post by BlackBart »
Yeah, I borrowed a compressor and it's hard to get the psi that low, or steady. Roadside inflator is an idea!
Regarding my Highlander snark - here's the reason...I saved this funny long ago and drag it out occasionally.
Highlander kid.jpg (182.55 KiB) Viewed 687 times
or....if you get tempted by miniature vans, I have this handy public service announcement to go with it.....
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
Changed my oil, swapped my tires (snow vs rest of year), cleaned my cabin filter and tried to debug my random stalling issue.
When I went to log my oil change, I discovered that the last time I did a change, it was 8/2019. Couldn't believe that. 5000miles but 1.5 years.
-A
