an after the fact question about disconnecting the battery Topic is solved
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
Is disconnecting the main power cable at the fuse box (Big red one) just as good as disconnecting the battery clamp from the battery itself? Yeah I'm Lazy - with a wagon, there's a few layers to dig through to get to the battery..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
RickHaleParker
Been thanked: 981 times
Post by RickHaleParker »
Not as good.
1. Does not shut down the REM.
2. The correct order is:
  • A. Disconnect negative terminal.
    B. Disconnect positive terminal.
    C. Reconnect positive terminal.
    D. Turn key to POSII.
    E. Reconnect negative terminal.
D & E forces the control modules to reinitialize.
Active
Past
azureblue
Post by azureblue »
Thanks. I'm saving this. Good to know, and maybe I should initialize the car, since it's been a while..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
