240 quad headlights on an 850 ?
JamesMoore05
Year and Model: 1996 Volvo 850 t5
Post by JamesMoore05 »
Does anyone have any experience putting quad 240/740 headlights onto an 850 ?
I get they won’t be a straight swap, but would it be possible ?
Would it even look good ?
Has thanked: 1507 times
Been thanked: 3825 times
I havent seen that done here, but Im sure it has been.
Asking aesthetics from a country who thinks you play football, with your hands...Hmmmmm.
Do you ever notice there are no egg crate grills in the UK, too?
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
JamesMoore05 wrote: 30 Mar 2021, 08:41 Would it even look good ?
I would say no. The 850 lights are smart and functional, and designed to fit the shape of the nose.
Just one opinion....
Year and Model: 2001 V70
Has thanked: 929 times
Been thanked: 1004 times
Post by volvolugnut »
Two preliminary considerations:
Is the width of the dual 240 headlights wider than the 850 headlight space?
The 850 grill has a taper to the outside at the top. How would you adjust to this taper?
mdr1220
Year and Model: 1996 850R
Has thanked: 44 times
Been thanked: 7 times
Post by mdr1220 »
abscate wrote: 30 Mar 2021, 09:34 I havent seen that done here, but Im sure it has been.
What's wrong with egg crate grills? When I acquired my 850 it has one. The first one I ever seen, I like the different look.
Used to have a 01 c70 convertible
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Might be less work to design quad headlight Mounts and Bezels for the 850. Then 3D print the parts. One could use the stock headlights as a template.
BlackBart
Post by BlackBart »
I'll admit I'm a pretty biased person in design discussions, but there is some background.
The only reason the 1980 240 came with 4 round lights is because the silly American regulations prohibited the much much better single lens and reflector european lights, which was what the car was designed with. By designers.
It looks like it's startled, surprised. The proportions are all wrong.
It was designed to look like this, with accurately cut lenses, halogen bulbs, and good reflectors.
The later 240s went to 4 tiny rectangular lights, for the same reason - US regulations.
The 850 in the first year had taller headlights with one big glass and hi-low lamp. See the accurate cut-off of the light? It creates a sharp cutoff in the road straight in front of you so you don't blind oncoming drivers, and it kicks up to the right (in drive-on-the-right countries) to light up the Bambi's and the signs up ahead.
In '94, they went to a wider and less tall lens with separate low and high beam elements inside. The European "E-codes" have much better lenses and light output.
US on the right, E-codes on the left.... See the big difference in the lenses....
Then some aftermarket kit person decided to do this.....
fog lights installed.jpg (79.5 KiB) Viewed 1099 times
We're back to looking really surprised, and the lights are fighting the proportions of the car design. They're also too close to the middle, like cross-eyed.
Also - go to Daniel Stern Lighting and read about the light output of little 5 3/4" round lights vs the old single 7". You can only bounce so much light off those little reflectors.
http://www.danielsternlighting.com/home.html
There's a reason Cibie, Hella, and Marchal (rest in peace) were the best lights in the world. Bosch probably around 4th. The French ones were designed in the 50s and 60s so increasingly fast cars could see at Le Mans. Hellas came on Porsches and Mercedes.
So there's my spiel on this. Maybe way too serious! I don't want to discourage anyone from trying ideas out and having fun!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1253 times
Post by matthew1 »
BlackBart wrote: 30 Mar 2021, 14:00 I'll admit I'm a pretty biased person in design discussions, but there is some background.
In the 80s it was the "aero" headlight phenomenon... and us Americans couldn't have it. It finally showed up in 1984 on the Lincoln Mark VII. https://www.hemmings.com/stories/articl ... ghter-idea
Our DOT held back headlight tech, and continues to, from what I can find. https://www.lasermarketsresearch.com/la ... o-the-u-s/
Idiotic bureaucracy.
Also -> Amazon link
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
Well, my '78 264 GLE is going to have the spider eyes and the flathood, because I'm weird. I'll probably look into an H1/H4 conversion, though.
I do have some vintage Marchal fog lights to mount on it as well.
I do like how the 4 rectangular headlights and reflectors look on my '83 245. Very classy in my opinion.
