SUMMER 2021 is NIGH!!! Ac repair tutorial 2017 by JimBee, DIY
Has thanked: 1497 times
Been thanked: 3809 times
Bookmarking this one again as it’s awesome, and will be needed soon here in the North East!
https://s3.amazonaws.com/images.matthewsvolvosite.com/vo ... torial.pdf
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2650 times
Been thanked: 1240 times
Post by matthew1 »
Excellent tutorial, just great.
Also -> Amazon link
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
That version is 21 meg because the pictures are uncompressed. I've attached a version with compressed images that's under 1 meg which I had downloaded in 8/2018. Looks identical.
I have also attached:
The AC clutch fix PDF by Nathan Bryant
The AC refrigerant recharge thread by pfeener (which I thought was worth making into a PDF)
I also have the "AC evaporator replacement book" PDF written by CLC, both a 2008 and 2017 version. It clearly says "not to be re-hosted... without the consent of the author" at the bottom of each page so I won't upload it here. I would post the author's email address (also at the bottom of each page) but I'd hate for them to get spam. Did I get it from this thread?
Here are some other links from my notes. I haven't checked these in years:
"Step one: what is the refrigerant pressure in the system? Step two, what is the clutch gap?"
Video re: cycling, etc
Video re: clutch gap
Pic of temp cut off switch on compressor which can be jumped
The compressor bread clip fix
Measuring the clutch gap on a 2000 S/V70
"Never replace an a/c clutch only, the compressor will fail shortly after."
850 condenser and evaporator replacement
List of info links for condenser/evaporator work.
Good 2019 A/C thread
Can you tell that my A/C is dead and I've been preparing to fix it? I did this research and bought the parts for my old blue V70 but it got totaled before I did the work. Good thing I got a green V70 with the same problem.
AC repair for 850 - JimBee.pdf
(994.17 KiB) Downloaded 119 times
AC cluch fix.pdf
(544.82 KiB) Downloaded 120 times
AC refrigerant recharge.pdf
(69.97 KiB) Downloaded 130 times
FireFox31
.... and green is cooler on the electromagnetic spectrum, too
matthew1
Site Admin
Post by matthew1 »
FireFox31 wrote: 06 Apr 2021, 15:48 That version is 21 meg because the pictures are uncompressed. I've attached a version with compressed images that's under 1 meg which I had downloaded in 8/2018. Looks identical.
Thanks FF31! I swapped yours in place of the 20+MB version. https://s3.amazonaws.com/images.matthewsvolvosite.com/vo ... torial.pdf
There's some server-side caching happening, so I don't know when it'll make the new version available at that URL. So although the switch is global and permanent, it'll serve up the large one for some time.
Also -> Amazon link
Crap. I missed that. We used to ding our students for not scaling their pictures to fit the resolution of their microscopes.
Hmmm. That file is twice the size of my very first hard drive installed in an IBM XT PC. That screaming 8086 chip and it’s 16 bits
