Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Here you go :)
1999 V70 GLT
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Cool beans man, but what makes your solution better than the original design?
BMW 540i 2002
S70 Base 2000
Sveedy
Post by Sveedy »
Not saying that it is for a stock set up. But in my case it makes sense. Old engine with mods that build more pressure that needs a place to go. I'd heard of them before, but when the indy mechanic that I had diagnose and fix my intercooler problem " strongly " recommended I run one, I looked into them more. Pro : Engine breaths better and doesn't have all that crap run through it, so it lasts longer. Con : It can smell sometimes, particularly sitting in traffic.
But I never do that :)
1999 V70 GLT
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Better off getting that garbage out of your engine! It’s all getting recycled with the used oil, so you might as well help out your engine.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Narrowly avoided disaster. There was a bit of crud in the orifice, thought it was a T25. Finally took the whole thing out, housing and all. Heat, juice, heat, juice b, heat, juice c, T27, DeWalt.
Has thanked: 1503 times
Been thanked: 3817 times
Is that the -1998 oil thermostat?
Has thanked: 1846 times
Been thanked: 1710 times
That definitely looks like a -98 oil engine oil thermostat. Before you re-fit, make sure the 2 'O' ring seal wells are spotlessly clean where the oil cooler lines go. They leak as the plate bends with age and can build up a layer of sharp crusty oil that can shred the 'o' rings when re-fitting.
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
Sveedy wrote: 17 Apr 2021, 11:07 Here you go :)
Would have loved to to see some pictures during install. Good Job!
Sveedy
Post by Sveedy »
Well I had the indy shop do it since they had everything all apart and seemed to know what they were doing, especially regarding turbos. Pretty simple as I recall;
Trap box still in place on the block, but the large hose coming off the top of it goes to the catch can instead of the PTC. That's the hose coming up through the intake. The hose that comes from the head also goes directly to the can instead of the stock trap box.
Both ports on the PTC are capped off as is the small port on the passengers side of the intake. And there is a drain hose with a small lever valve coming off the bottom of the can for easy draining. Can has a tab that mounts to the battery tray. I have found that putting a old sock over the breather element stops any oily vapors from making any sort of mess, as well as acting as a pre-filter. I figure that after I get the engine issues sorted out this summer, I will modify the hose coming off the head so I can put my spark boot cover back on, but I think I will keep running the can system regardless.
1999 V70 GLT
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Doing some usual P80 maintenance things
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
