bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Replaced the AC condenser on the S70 today. I went to charge the AC last week and realized that there was a puncture from the collision. Fortunately it was very easy to stop right out without touching the radiator or intercooler. Just used a ratcheting 10mm to take off the lower screws, then a swivel socket on the top left, and a flex head ratcheting wrench on the top right. It's a little tight to access those, but not impossible.
Also bled the brakes, first time using my Motive power bleeder. I love this thing! Makes it so easy, and because you're not using air, there are no bubbles in the line to cause you to wonder if it's from the bleeding device or from air in the fluid.
Has thanked: 1505 times
Been thanked: 3818 times
Took Dirks advice and ran the Bridgeport CT to Albany commute via route 7
About an extra 30 minutes but I was in the zoomy Man Beetle , 180 HP 5 speed and was totally worth it!
viewtopic.php?f=38&t=97111
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
abscate wrote: 04 May 2021, 05:14 Took Dirks advice and ran the Bridgeport CT to Albany commute via route 7
I am glad you enjoyed it. I've been living in southwest NE for over 20 years now, but only over the last few years I realized how beautiful this part of the country really is.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
850 LPT
Post by 850 LPT »
Evap time for "Harold" the 850. Honey, can you hold this for a sec?
There are few things hotter than women holding a dashboard...are you good to go with vacuumpump and manifold or do we need to make plans?
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
I think I found the misfire....
bmdubya1198
Eeew... that's pretty crusty!
ZionXIX
Post by ZionXIX »
bmdubya1198 wrote: 04 May 2021, 09:09 Eeew... that's pretty crusty!
2years and 8,000 miles. I have no idea how it got so corroded.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
ZionXIX wrote: 04 May 2021, 12:15
Us Sailors call that stuff 'spooge'.
Double-check inside the cap; sometimes a steady miss can cause spark tracing.
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 328 times
Been thanked: 87 times
Post by CIK7 »
Today I replaced both rear Sachs shocks, rear ceramic brake pads. Also I swapped the insane aftermarket 17" with my set of s80 base wheels. Tomorrow it will be more complicated...with the front. I like that i have a rare higher trim base model.
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
