Spark plugs - what do u think
toolpusher
Year and Model: 2007 XC90
Has thanked: 3 times
Been thanked: 3 times
Post by toolpusher »
Spark plugs replaced from 2010 3.2 at 111k miles (not the one from the catalytic converter thread). To the experts: what do the spark plugs tell me in terms if the engine?
Thank you!
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
If you are having to add oil between changes then I would recommend a new PCV.
They should look like this (except for number 2 which has a problem)
The way the PCV system routes the Vapors (and oil if its broken) is in a channel that connects all 6 intake ports
Start 6 - 5 - 4 - 3 - 2 - 1 finish
Because of this plug #6, #5 will be worse than plug #1, #2 (and I think that you have that)
If the plugs have been in there for a long time you could drive with the new plugs for a month and check #6 before replacing the PCV
Take Care
Paul
pbierre
Year and Model: T6 XC70s: '13 & '15
Been thanked: 12 times
Post by pbierre »
These plugs look the same as the set I pulled out of my 2013 XC70 at 110K miles. The gaps are a little enlarged, due to the positive electrode tip wearing down. If there's anything besides normal wear and tear, it doesn't show in the photos.
Over the course of 50K miles, a spark plug will fire 200,000,000 times.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
All pictured spark plugs look to be equal visually, meaning your cylinders and related are consistent. They have excess oil/coke deposits. This could be b/c of short driving distances, PCV system, or worn rings. I bet on short driving distances. So they look normal for short driving distance usage, but as you can see the results are not optimum. It is not just the spark plugs.
pgill
Post by pgill »
pbierre wrote: 09 May 2021, 20:14 These plugs look the same as the set I pulled out of my 2013 XC70 at 110K miles. The gaps are a little enlarged, due to the positive electrode tip wearing down. If there's anything besides normal wear and tear, it doesn't show in the photos.
Those plugs look original FoMoCo
I change mine at 50,000 mile intervals on my 3.2s
The replacements that you bought are the wat to go.
Note: the center wire on the Iridium TT 4704 is slightly thinner than the Stock Iridium plugs 3421 that you removed
Smaller wire advantages
+ Less work for the coil to create a spark
+ Less likely for the spark to quench (this is important for catalyst efficiency checking)
- Smaller wire will wear out faster
Did I mention a 50,000 mile service interval
Good luck
Paul
pgill
Post by pgill »
Toolpusher,
Based on your posts it looks like you have two 3.2s
I do as well.
Both of yours seem to have a sticking PCV Valve.
You can use the Land Rover part if you like
LR023777
The same part in a Volvo box cost almost 2X Volvo part number 31319642
Note: the 3.0T is different than the 3.2
A less expensive option is to just replace the diaphragm and cap (I tried to remove the cap on my LR2 and it cracked, but a new cap would solve this issue)
Some picture of my LR2
https://www.freel2.com/forum/topic32107.html
I think one of your 3.2s is consuming a lot of oil, if you don't have any leaks then the PCV should fix the oil consumption.
Good luck
let us know what you do and if it works
Paul
toolpusher
Yes indeed, two 3.2s. One at 111k (this thread) and one at 147k (the oil burner). Next is thermostat and manifold gaskets on the 147k, and now I am adding PCV to the list :)
pgill
Post by pgill »
toolpusher wrote: 19 May 2021, 21:04 Yes indeed, two 3.2s. One at 111k (this thread) and one at 147k (the oil burner). Next is thermostat and manifold gaskets on the 147k, and now I am adding PCV to the list :)
Nice!!!
I would change the intake manifold gasket and clean the throttle body when you change the thermostat.
But I wouldn't change the exhaust gasket unless you have a leak or a check engine light.
Good luck
Paul
toolpusher
pgill wrote: 20 May 2021, 11:50 I would change the intake manifold gasket and clean the throttle body when you change the thermostat.
Thank you! Do you recommend pulling the throttle body of and then - probably - replace the gasket, or leave the throttle body on the manifold and clean it just from the outside?
pgill
Post by pgill »
toolpusher wrote: 21 May 2021, 10:29 Thank you! Do you recommend pulling the throttle body of and then - probably - replace the gasket, or leave the throttle body on the manifold and clean it just from the outside?
I didn't change the throttle body gasket on mine, I just cleaned it and reused it.
Note: the gasket is compressed by the throttle body and as long as it is compliant then you can reuse it.
The Land Rover part number is LR001462 (throttle body gasket)
Its a little expensive $24 https://www.oemdiscountcarparts.com/oem ... t-lr001462
I do recommend that you change the small gaskets Qty 6
LR001454 (I replace these every time I remove the manifold)
I use the Victor Reinz part $2.35 each https://www.rmeuropean.com/Products/LR001454-MFG17.aspx
The price is low but the quality is excellent for these parts.
Note: these small gaskets by the cylinder head will be contaminated by oil if your PCV is not functioning and they will lose their flexibility and their ability to seal. Which is why I always replace mine.
If you want the small gasket in a Volvo box then FCP sells them for $17 each https://www.fcpeuro.com/Volvo-parts/S80 ... b=5&d=3597
List price is about $25 each
Get the Victor Reinz parts you won't be disappointed.
Thanks
Paul
