- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Have you ever found yourself with bruised hands because you pulled too long on too short a handle? And then banged on said handle with your palm?
- DonnVa
- Year and Model: 2005 XC70
- Has thanked: 21 times
- Been thanked: 61 times
After almost a year of general and much needed maintenance, I finally did something cosmetic. I picked up a set of toasty Echo rims at a pick a part a few weeks ago and refinished them. I got my Michelin’s mounted on them last night. I’m going to scuff them after they cure and hit them with a couple more coats of clear. Overall, I’m pleased with the way they turned out. Hind sight 20/20 though, I probably should have hit them with a gloss black and laid the silver over it to give them a deeper silver color.
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
Ripped off a quick front brake job on Catherine the P2
50,000 on these. It looks like the right front caliper is sticking, will have to watch it
Control arm bushings shot. , need new ones
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
thats like finding $1000 in your bank account.cleven wrote: 15 May 2021, 17:30 Well i looked and seen the PVC system has been recently done on my new to me v70. Big plus for me lol.
- kcodyjr
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 17 times
- Been thanked: 23 times
Both front control arms.
What a PITA that is on a 2006 S60... Done without removing the knuckle. Used a jack to lift the knuckle so as to not overstretch the new control arm bushing when getting that ball joint stud through the hole.
Still, a royal PITA. Next time I'll do it by taking out the knuckle, even if the tie rod end ball-joint bolt does look as rusty as the Titanic...
Had the brake dust shields out for that, so they got a nice spray-down with brake cleaner, and then installing new rotors was as easy as a new fuse after all that. Still waiting for rebuilt calipers to complete the reassembly.
5 others that came and went
- jonesg
I was able to reseat the balljoint stud in the control arm by removing the large upper knuckle to strut clamp bolt, then loosen the lower bolt so the knuckle can pivot. Ratchet strap pulled the control arm down as far as possible.kcodyjr wrote: 17 May 2021, 22:20 Both front control arms.
That’s clever. You can even c clamp it closed again when done.
- kcodyjr
I like it. That way, the axle bolt doesn't have to come out.jonesg wrote: 19 May 2021, 09:22 I was able to reseat the balljoint stud in the control arm by removing the large upper knuckle to strut clamp bolt, then loosen the lower bolt so the knuckle can pivot. Ratchet strap pulled the control arm down as far as possible.
Next up, I get to R/R all four brake hoses. I don't suppose there's any bookies around here that wanna take bets on whether that goes smoothly?
