How did you do your transmission? Topic is solved
cleven
Year and Model: 2001 V70 T5
Been thanked: 5 times
Post by cleven »
Got a 2001 v70 FWD, I am gonna be doing the transmission on next week. I was wondering how have some of you went about it? Iv seen readings on some taking the motor and trans out from up top, and iv seen readings on taking it from the bottom while supporting the engine and dropping the sub frame. How have some of you done it? FYI ill be having access to a lift.
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Search the posts for engine removal. You should find lots of comments. I have not pulled these engines, but the choice of top or bottom, looks to me to be determined by your equipment access. A lift would suggest out the bottom, but I think you would still need a way to lower the engine down.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I take tranny and engine as one and lift it out the top. Had I had a lift I would have done it like Ed China and dropped it down on a rolling tool cart or something.
BMW 540i 2002
S70 Base 2000
kourt
Year and Model: 2005 XC70
Post by kourt »
I just removed/reinstalled the transmission on my 2005 XC70. That involved removing the wheels and axles, installing support bars over the engine bay, removing the subframe, lower the whole assembly, and removing the transmission through the left wheel well.
kourt
Has thanked: 1505 times
Been thanked: 3817 times
I’ve done both the lift and the drop.
The lift is much easier
cleven
Post by cleven »
volvolugnut wrote: 16 May 2021, 09:10 Search the posts for engine removal. You should find lots of comments. I have not pulled these engines, but the choice of top or bottom, looks to me to be determined by your equipment access. A lift would suggest out the bottom, but I think you would still need a way to lower the engine down.
I have an engine support to hold and lower the engine. Looks pretty straight forward. Only difference from these and other cars i have done are the torque converter bolts
cleven
Post by cleven »
kourt wrote: 16 May 2021, 11:10 I just removed/reinstalled the transmission on my 2005 XC70. That involved removing the wheels and axles, installing support bars over the engine bay, removing the subframe, lower the whole assembly, and removing the transmission through the left wheel well.
kourt
Yeah I think I just made it harder than it actually is in my head to be honest. Iv dropped subframes before now that i get a good look at it its not much to it.
cleven
Post by cleven »
Came on my lunch break to put it on the lift. Tomorrow night the fun starts.
Very jealous of your lift access.
cleven
Post by cleven »
I didn’t think these transmissions where so tiny
