2000 V70 AWD 56 engine slow coolant leak
Has thanked: 1853 times
Been thanked: 1712 times
Re: 2000 V70 AWD 56 engine slow coolant leak
What you suggest should work fine. You have to weigh up the time for a do-over if there is an issue. AS this is a small repair and the radiator is not at huge pressure I don't see why it won't work. Worth a try and if it is good, sell the 'new' radiator and get most of your money back.
Has thanked: 1506 times
Been thanked: 3820 times
Rocket99 wrote: 20 May 2021, 14:54 no no
I was traumatized while a volvochild very young and never got over it had to replace engine
. Nothing on the ground, takes maybe 2 or more months to drop 1 inch.
just carry some along with....
I would cross the country with that “ leak” , let alone a brief saunter down Route 5
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
I would do a cooling system contamination test to check for combustion gases in the cooling system.
Does the system seem to hold pressure for a long time?
We had an issue with the original engine in my wife's '97 GLT LPT. It had been overheated a couple times previous to us getting it and fixing the fan issue. It ran fine, but the coolant level slowly dropped and the system would hold onto a little pressure for a couple of days. Like I would go out to it after it had been sitting for 24+ hours and it would vent pressure when I opened the reservoir.
After looking high and low for any kind of coolant leak and finding none, I caved and did the combustion gas test.
The fluid is supposed to stay blue and only turn yellow if there are combustion gases present in the cooling system.
Signs of a very slight HG leak, so we eventually swapped motors in the car.
If it's not holding pressure for an excessively long time, then you *may* not have an internal leak, but the tester is inexpensive and worth it for diagnostic purposes.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
The other sneaky place coolant can escape and hide is the heater core/bulkhead connection spaces. Diagnostic is feeling the carpet under the gas pedal. That's how I caught it on my first 850, but only after I had already replaced the radiator.
Vivere et discere
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Buy a cheap kit so you can introduce pressure to the coolant system. Very handy to find leaks. HF sells a cheap kit.
BMW 540i 2002
S70 Base 2000
Rocket99
Year and Model: 2000 V70 XC
Has thanked: 56 times
Post by Rocket99 »
Got home from a run into town 2 days after topping up coolant. The coolant in the reservoir is one inch higher when hot from this run than it was when cold.
Got out the old block leak tester, fluid remained blue. There does seem to be some source of pressure developing in the cooling sysytem, it wants to push the coolant level higher in the reservoir.
Oh shit.
Rocket99
Post by Rocket99 »
[/quote]
now the coolant was one inch higher in reservoir that when cold after warming up on a trip to town.
Block tester fluid remains blue but I can see there is new volume added to the coolant space .
freaky looks very bad
foggydogg
Post by foggydogg »
Rocket99 wrote: 21 May 2021, 11:31 I would cross the country with that “ leak” , let alone a brief saunter down Route 5
[/quote]
If you're saying it's an inch higher while it is still hot, that is normal. If it's still above the full mark after it cools to ambient, then as Neil mentioned, there could be an air pocket.
No exhaust in the coolant is a good thing.
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
I second the mention to look under the driver's floor mat for coolant leaking from the heater core. I let that go on way too long in my last 2000 V70.
What does it mean when pressure remains in the coolant system for 24+ hours after driving? How can this be quantified and diagnosed to be an actual problem?
FireFox31
FireFox31 wrote: 21 May 2021, 23:30 I second the mention to look under the driver's floor mat for coolant leaking from the heater core. I let that go on way too long in my last 2000 V70.
It means everything is nice and tight and you have no leaks!
