Hi Folks.
car: 99 s70 base.
I discovered that my coolant temp sensor insulation is damaged but the sensor still works find.
I want to remove it and apply some silicone or some heat shrink to deal with the damaged insulation.
My question is can I remove the thermostat housing without losing much coolant?
I've never removed the housing without draining radiator first.
If I lose a little, no big deal. If i'm going to lose 50% of the coolant out the top, I'd rather drain from bottom first.
-A
question on removing thermostat housing
bronco
- Year and Model: 1998 V70
- Has thanked: 39 times
- Been thanked: 24 times
drain it less mess overall, the housing might not be as simple as you think . Mine the torx back bolt was stripped and removing the whole housing from the block means getting at the bottom bolt which is blocked by a few things
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
That is true. However in my case, I put in a new thermostat in a couple of years ago. The torx bolts came out fine on mine and I used anti-sieze when putting them back in.
I do appreciate the warning though. They can be a giant pain.
-A
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Save yourself major headaches and replace the sodding torx head bolts with intake manifold bolts. Same length, thread pitch, and diameter, same grade too...just hex headed. Part number inc whenever I remember to look at the blue bag in the shed.
