question on removing thermostat housing
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
Hi Folks.
car: 99 s70 base.
I discovered that my coolant temp sensor insulation is damaged but the sensor still works find.
I want to remove it and apply some silicone or some heat shrink to deal with the damaged insulation.
My question is can I remove the thermostat housing without losing much coolant?
I've never removed the housing without draining radiator first.
If I lose a little, no big deal. If i'm going to lose 50% of the coolant out the top, I'd rather drain from bottom first.
-A
bronco
Year and Model: 1998 V70
Has thanked: 39 times
Been thanked: 24 times
Post by bronco »
drain it less mess overall, the housing might not be as simple as you think . Mine the torx back bolt was stripped and removing the whole housing from the block means getting at the bottom bolt which is blocked by a few things
amblerman
Post by amblerman »
bronco wrote: 27 May 2021, 10:22 drain it less mess overall, the housing might not be as simple as you think . Mine the torx back bolt was stripped and removing the whole housing from the block means getting at the bottom bolt which is blocked by a few things
That is true. However in my case, I put in a new thermostat in a couple of years ago. The torx bolts came out fine on mine and I used anti-sieze when putting them back in.
I do appreciate the warning though. They can be a giant pain.
-A
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Save yourself major headaches and replace the sodding torx head bolts with intake manifold bolts. Same length, thread pitch, and diameter, same grade too...just hex headed. Part number inc whenever I remember to look at the blue bag in the shed.
Cookeh
Post by Cookeh »
Cookeh wrote: 27 May 2021, 13:22 Save yourself major headaches and replace the sodding torx head bolts with intake manifold bolts. Same length, thread pitch, and diameter, same grade too...just hex headed. Part number inc whenever I remember to look at the blue bag in the shed.
P/N: 982778
