Etm or fuel pump relay
Soldion
Year and Model: 2003 S60
Has thanked: 3 times
Post by Soldion »
Would these have the same symptoms? Car died after stopping to get gas? Was running fine before. It did do this randomly for a couple of years; usually unplugging the battery for a minute would usually fix the problem except this last time.
Thanks
Specs:
03 S60 2.5T AWD
217456 miles
Update, more info:
OK, there is no CEL, new plugs, coils. it wasn't, flooded with gas, has over half of tank in it right now. There is no fuel pressure when I checked where the schedar( can't seem to remember how it's spelt) valve; unless some how I didn't do it right.
Has thanked: 1498 times
Been thanked: 3810 times
More likely fuel delivery than throttle body but that is way too sparse data for a decent diagnosis.
MDK
Year and Model: 2004 S60R
Been thanked: 41 times
Post by MDK »
Well soldion.. MDK here. I've had more than a few of these..I started with a 1997 850Rwagon a millenia ago. If it was me I try this.. it's on rockauto with the info you gave.
dj_v70
Year and Model: v70 2003
Has thanked: 7 times
Been thanked: 23 times
Post by dj_v70 »
Does this only happen immediately after getting gas? If so, is engine flooded ... is can you start the car if you floor gas pedal and crank for 20 sec?
I had above problem before. There is a vacuum switch that gets stuck open and floods engine while filling tank if it is stuck.
Soldion
Post by Soldion »
Updated post with more info
Been thanked: 466 times
Post by cn90 »
At that mileage > 200K miles:
1. FPR as posted above, but use on ly Bosch. Very easy DIY.
2. Search forum for PEM: it can be anywhere: under the car, in the trunk etc.
Get a good used one on ebay for $50 or local junk yard.
If you swap and it works, then you know it is a bad PEM.
I posted some tricks in this forum.
You may need a 7-mm socket...
viewtopic.php?t=87748
Soldion
Post by Soldion »
OK I will look at for PEM tomorrow morning, to see what it looks like.
Soldion
Post by Soldion »
Weather hasn't allowed me to look for it.
Soldion
Post by Soldion »
Ok I ended up buying a FPS cause its cheaper. While I was waiting on the sensor to get here, I figured I'd look at the PEM. Well I never could find it. Looked in the spare tire compartment, and couldn't tell if its on top of the tank, I can't even get my hand up there. So couple of more questions..
Do I have to drop the tank to get to the PEM or is it behind the wheel well?
Would dielectric grease be ok to use a lubricant for the sensor?
Thanks
