Would these have the same symptoms? Car died after stopping to get gas? Was running fine before. It did do this randomly for a couple of years; usually unplugging the battery for a minute would usually fix the problem except this last time.
Thanks
Specs:
03 S60 2.5T AWD
217456 miles
Update, more info:
OK, there is no CEL, new plugs, coils. it wasn't, flooded with gas, has over half of tank in it right now. There is no fuel pressure when I checked where the schedar( can't seem to remember how it's spelt) valve; unless some how I didn't do it right.
Etm or fuel pump relay
- Has thanked: 1497 times
- Been thanked: 3810 times
More likely fuel delivery than throttle body but that is way too sparse data for a decent diagnosis.
Well soldion.. MDK here. I've had more than a few of these..I started with a 1997 850Rwagon a millenia ago. If it was me I try this.. it's on rockauto with the info you gave.
- 0261230110front__ra_m.jpg (11.61 KiB) Viewed 782 times
dj_v70
- Year and Model: v70 2003
- Has thanked: 7 times
- Been thanked: 23 times
Does this only happen immediately after getting gas? If so, is engine flooded ... is can you start the car if you floor gas pedal and crank for 20 sec?
I had above problem before. There is a vacuum switch that gets stuck open and floods engine while filling tank if it is stuck.
- Been thanked: 466 times
At that mileage > 200K miles:
1. FPR as posted above, but use on ly Bosch. Very easy DIY.
2. Search forum for PEM: it can be anywhere: under the car, in the trunk etc.
Get a good used one on ebay for $50 or local junk yard.
If you swap and it works, then you know it is a bad PEM.
I posted some tricks in this forum.
You may need a 7-mm socket...
viewtopic.php?t=87748
Soldion
- Year and Model: 2003 S60
- Has thanked: 3 times
- Been thanked: 2 times
Ok I ended up buying a FPS cause its cheaper. While I was waiting on the sensor to get here, I figured I'd look at the PEM. Well I never could find it. Looked in the spare tire compartment, and couldn't tell if its on top of the tank, I can't even get my hand up there. So couple of more questions..
Do I have to drop the tank to get to the PEM or is it behind the wheel well?
Would dielectric grease be ok to use a lubricant for the sensor?
Thanks
Thanks
- 4378 Views
Last post by wizechatmgr
- 11 Replies
- 2033 Views
