MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
Just got my aisin t-lV from rockauto so I can flush the transmission fluid on my R car. I've had good success with them. Look at the magnet they sent me! MDK
cleven
Year and Model: 2001 V70 T5
Been thanked: 5 times
Post by cleven »
Fuel pump yay 😂
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
Got the state inspection and put it into service after a month and a half of post-purchase reconditioning.
Up to 75mph, it drives nearly perfect. A vibration at higher speeds, and a slight twitch crossing center in the steering, suggest it could use a new set of tires and and alignment.
It might have a minor exhaust leak. I'll need to have someone put it on a lift and look using a probe. If it's there, it's not bad enough to find with mark one eardrum and a set of ramps.
It's got a pronounced turbo whistle when I'm into the pedal. Since I'm not getting a CEL for the MAF reading being out of whack, I'm guessing it's either normal for this car, or the turbo is beginning to get worn? Not sure there.
As it happened, the 1997 Camry it's replacing got T-boned on the way back from the double-date inspection appointment, so the S60 is REALLY in full time service now... with a few things yet to be done.
Do these cars tend to have a generally soft brake pedal feel? It's got no shortage of brake authority, in fact its stopping distance seems excellent to me, but the pedal seems to have a squishy feel. I checked the pad retainer clips, they're correct. Air in the lines? Or is that just how these cars are?
5 others that came and went
Been thanked: 4068 times
Brakes should be nice and firm. Once in a while, if all the fluid runs out, you have to go into VIDA and activate the pump to get the air out of the system
Nice timing on the refurbishment. RIP Toyota, hope the important parts,the ones with fingers and toes, are all ok.
kcodyjr
Post by kcodyjr »
abscate wrote: 05 Jun 2021, 06:34 if all the fluid runs out, you have to go into VIDA and activate the pump to get the air out of the system
Is it that simple, or do I need to do it while bleeding or something like that?
abscate wrote: 05 Jun 2021, 06:34 Nice timing on the refurbishment. RIP Toyota, hope the important parts,the ones with fingers and toes, are all ok.
For real. Yes, everyone is okay. It was one of the light t-bonings; the car is still serviceable, it just LOOKS like a 24 year old s***box now.
kcodyjr wrote: 05 Jun 2021, 06:55
I’ve never had to do the VIDA bleed but one of our clubbers did. You have to open bleeders and then activate the pump in software. Alternatively, drive it fir a bit, then rebleed. Is this one staying on Chappy or does it go up to nasty Boston ?
kcodyjr
Post by kcodyjr »
abscate wrote: 05 Jun 2021, 07:00 Is this one staying on Chappy or does it go up to nasty Boston ?
I try to stay out of Boston. When I go off-island, it's either to the Cape or Plymouth county, or to the towns near and west of Lowell.
This will be the primary off-island excursion car.
Has thanked: 311 times
Been thanked: 817 times
Washed 'em. Oak pollen and bud drop season is finally over.
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
Yesterday I swapped out the driver's side sunvisor for one that has a mirror door that stays shut/open when it's supposed to rather than flopping around like the old one did. I also installed a driver's door inside pull handle, the big plastic piece used to close the door.
Today I swapped out the left rear door module. Still having a bit of trouble getting the door handle rod to clip onto the door module's blue clip, but I'll get it hopefully.
I also took pics of my front leather seats, since I guess not many people have seats without rips or tears in them. Mine have grease on them from working on the car but it'll wipe off when I get around to it.
Here's my front seats...
cleven
Post by cleven »
Just bought a "Foseal" scanner off a guy. Now i can test my throttle body and mass airflow sensor!
