Possibility of 2000 V70XC parts fitting 1997 850 T-5
hipcheck
Year and Model: 1997 850
Has thanked: 6 times
Been thanked: 7 times
Post by hipcheck »
There is a really clean 2000 V70 XC at the pull it yard. I would like to spruce up my interior on my 1997 850.....
Would any of the following swap out:
Steering wheel
Power seats
Console/cup holder
Rear tailgate trim (tailgate, overhead area, panels that cover the tweeters and lift gate shocks)
I can not believe I didn’t look at the dash pad while I was there...maybe that too?
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
There is very little that will crossover on the interior. Pretty much all of the panels are different.
I can't say for sure, but I do think the steering wheel will swap. I've seen some later wheels swapped into 850's.
The seats can be mounted to the 850 tracks, IIRC, but there is a difference in the SIPS stuff and I'm not sure if you wind up losing that function with the swap.
That XC should have a good larger front sway bar. The one I have in my '97 T5 came from an '00XC and it's 21.5mm. (Yellow/blue paint markings)
Has thanked: 311 times
Been thanked: 817 times
You can swap the whole tailgate, all 93-00 are compatible with each other for the hatch, but as Chuck mentioned I'm pretty sure none of the surrounding interior panels will swap.
hipcheck
Post by hipcheck »
I already have the IPD sway bars but knowing it is an upgrade I might grab it for someone else.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
hipcheck wrote: 06 Jun 2021, 16:23 I would like to spruce up my interior on my 1997 850.....
The P80 70 series is a 850 with a make over.
Being both P80 cars. Most of the interior should swap. There will be some difference like the dash sticks out further on the V70. If you swap the dash you will need to swap the front door panels also.
Front nose clip is transferable across all the P80s. Make sure you get the brackets along with the nose clip.
Nose clip: Hood, fenders, grill, headlights .. ect as a single unit.
Active
Past
RickHaleParker wrote: 06 Jun 2021, 22:23
Yes, true fact
RickHaleParker wrote: 06 Jun 2021, 22:23 Being both P80 cars. Most of the interior should swap.
Actually Rick, almost nothing swaps. Perhaps if you swap absolutely everything it would all mount up, could be worth some searching to figure that out. I think you are right people have Frankensteined in the dash before, however.
RickHaleParker wrote: 06 Jun 2021, 22:23 Front nose clip is transferable across all the P80s. Make sure you get the brackets along with the nose clip.
True, you can swap all the front end body panels as a unit (the "nose"), there is documentation on that in this forum from people who have done it. But piecemeal, only the tailgate.
OP you also asked about the tailgate shocks - those will definitely swap. They are really a mechanical item - a great majority of mechanical items will swap.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
The armrest part of the center console with the included arm rest swaps over. The V70 one is superior to the early 850 one
1996 855 R,
2010 V70 D5,
RickHaleParker
Anybody got pictures of 850 / 70 crossovers?
Active
Past
Chuck W
Post by Chuck W »
RickHaleParker wrote: 08 Jun 2021, 04:53 Anybody got pictures of 850 / 70 crossovers?
Interior or exterior?
I have an XC70 snout on my '97.
There is a user on SS that has swapped a '98 dash and interior harness into his 850. (It's a track car, so no full interior, but has a full working '98 dash and windows (Door controls are different as well)
RickHaleParker
Chuck W wrote: 08 Jun 2021, 05:05
Either one.
I no longer wonder what a XC70 snout looks like on a 850.
Still wondering what C70 snout would look like on a 850, S70, V70 or XC70.
Active
Past
